Radio volume turning up or down
Sgt_Slacker
Illinois
2019 Wrangler unlimited
So I have 19JLU Sport s I have the tech group with the 7” display. Once in a while if I adjust the volume it will keep going up or down anyone having similar issue?
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
@Sgt_Slacker
Some with the 7" have reported this in the past and no resolution of the issue was ever posted.
Do in radio settings turn off the option that has sound adjust upward with speed of vehicle...
Also.... when the issue occurs..... try changing modes from FM to AM...... Supposedly this will correct the issue for the instance / when the issue occurs..
Sgt_Slacker
Illinois
@Sgt_Slacker
[/QUOTE
So I don’t use the actual radio I pretty much only use apple car play. And I don’t think it’s the speed comp because I actually see the volume numbers increase or decrease
Gee-pah
Andy
SanFrancisco
JL Wrangler
Jeff: somewhat tangential to your problem, please be advised that the JL can have more than one volume setting, e.g. Siri, Radio, etc.
Sgt_Slacker
Illinois
@Sgt_Slacker
Sgt_Slacker
Illinois
When it happens all I have to do is touch the volume adjust and it stops. Its just weird doesn't happen all the time.
Wkywhitealtitude
Jordan
Ohio
Jeep gladiator, Jeep Wrangler JLU
I have a gladiator and have this same issue but I have a 8.4 my volume will change on its own, the speed volume adjust is off and all i have is my phone playing music to usb via apple cord, I can touch the volume Knob and it goes back to normal
Jeepiner
Jeepineer
Toledo, OH
2022 JLURD
Mechanical Engineer
@Sgt_Slacker
2022 JLURD with 8.4" Uconnect here.
I've been plagued with this issue ever since I took delivery. No matter what phone I used, or whether I was using CarPlay or Bluetooth, the audio levels would randomly drop for absolutely no reason. It drove me crazy at times because it would happen seemingly every 5 seconds. Other times, maybe once every 30min, sometimes not at all. Very inconsistent, random and sporadic.
I went through both the Uconnect settings & phone settings, separately eliminating possibilities one by one to no avail.
It wasn't until I saw your reply to this post, that I finally just went into the Uconnect radio (which I never use), and switched the FM & AM back and forth a couple times (also turned off HD for both).... that resolved the issue, for now anyway. Hopefully that fixed it forever.
I know I'm resurrecting a thread here, but this is the only post I've seen that suggested a solution which oddly enough actually works. Thank you!!
simpleJL
Kyle
East Bay, CA
'18 JLUR
Same same with me.
Do you have a tazer installed?
Jeepiner
Jeepineer
Toledo, OH
2022 JLURD
Mechanical Engineer
Same same with me.
Yep. Still dealing with the issue.
The switching AM/FM only works temporarily, only for that engine start cycle it seems.
simpleJL
Kyle
East Bay, CA
'18 JLUR
I think it’s a tazer glitch. Crazy it has been happening for so long and they haven’t fixed it.
