Pulling hard to the right under hard braking
hamiamham69
Nantucket MA
2019 Unlimited Sport
I have a 2019 JLU Sport with 3.6L / Under gentle to moderate brake pressure, the Jeeps stays in a straight line and brakes as it should. Under hard pressure, the Jeep pulls to the right side. What can I check for first before calling in the mechanic?
jludave
The Isle of Long
IT Manager
Check for a stuck caliper piston on the side that the vehicle is pulling to. Check the brake pads as well. Most likely will need a qualified mechanic/shop to diagnose.
rickeyf413
Rickey
Baton Rouge, LA & Charlotte, NC
2021 Jeep Wrangler JL 2-door Islander Edition
IT Director
I had the same issue with my 2021 and it ended up being the caster was off. I replaced the front and rear control arms with adjustable ones and it no longer pulls to one side during braking.
Craigger
San Diego, CA
2022 JLUR XR
I agree with @jludave that it's likely a sticking caliper. Are you using stock wheels? If you have aftermarket with much less backspacing the scrub radius will have changed which would really amplify the issue.
hamiamham69
Nantucket MA
I sold the stock wheels and tires and bought take-offs from a Rubicon 4xe. The wheels are still 17” but the tire sie is 275/70
Margaritian
Ohio
2024 Wrangler JL Sport S unlimited
My wife's 2015 JK Sport had this issue twice, about 2 years apart. First the passenger side, then the driver's. Both times it turned out to be a collapsed brake hose.
JeepinPete
Pete
PA
'19 Mojito JLUR
Mechanical Engineer
Check the caliper opposite the side it is pulling to. If one of the pistons is stuck, the braking force on the side is cut in half.
Pete
Left Field
Tim
Western WA
'67 RS-SS Camaro, 2021 JLUR392
If you happen to have access to an Infrared thermometer it's a simple way to see how your brakes are behaving relative to each other. If one is pulling too much or not enough it shows up in the temperature readings.
LF
