Proper air pressure
Coinman
Michael
2021 Jeep Rubicon eco Diesel
How much air should you run in 35 inch BF Goodrich tires? I just bought 2021 jeep rubicon diesel and it has 26 lbs all the way around it. Seems low but is riding good. Please advise!!
Philly_
Dallas / Detroit / NYC
2022 JL Rubicon
If the tread is wearing evenly and it rides alright, then 26 is fine. With aftermarket tires it depends a lot on the weight of your Jeep and the stiffness of the sidewall of the new tires.
I ran 21psi in two sets of 35x12.50r15 Goodyear MTR/k’s over the course of about 6 years on my JKU with no issues. Any more pressure and I wasn’t getting good tread wear.
Coinman
Coinman
Michael
Philly thanks for the info. Tire ware and handling so far is great so I will stay with this unless I see uneven tread.
R3TRO
Pasadena, CA
'20 Jeep Willys
Film Industry
Wait until summer... those babies will be in the mid 30's psi with the heat. Mine vary from 29psi to 38psi depending upon the temperature. It drives me crazy because sometimes the low tp warning will go off.
timn1984
Tim
Louisville, KY
Jeep Wrangler Unlimited 2018 JL Sahara,Dodge Journey 2012, Toyota Camry 2015
Yes
Yes I live in Kentucky and this crazy weather creates many problems for my tires. Goes from low 30's to 75-80 degrees in one day. My pressure has been all over the board this year.
Chocolate Thunder
Jeremy
For best wear probably low 30s cold pressure. For best handling and ride probably high 20s. I’m in Texas too and typical pressure rise from cold tires is 3-4 psi when running.
