Play in pitman arm
Atom631
Atom
New York
2021 JLUR
ive been chasing a knock the steering of my 2021 JLUR. I have the steersmarts sector shaft brace. I tracked it down to the sector nut being loose. in turn I think it was putting a lot of pressure on the cartridge bearing so when I pulled it apart the bearing felt crunchy.
I ordered a new brace w/bearing and installed it with 177’ lbs torque. now im noticing there is some slight play in the pitman arm. see video below. im assuming this isnt normal snd ill need a new arm?
Carolina Jeeper
Rollie
North Carolina
No, the pitman arm is the toughest part of the steering linkage.
I would check the piyman nut torque and sector shaft for play in the bearing there before simply replacing the pitman arm.
Atom631
Atom631
Atom
New York
2021 JLUR
the nut is brand new and was torqued to 178 ft/lbs.
if its in the sector shaft, I guess I need a new box?
Old Jeeper
Don
US Army Infantry, IT Engineer
X2
There should NEVER be any play in the pitman arm, if so you have a real problem.
roaniecowpony
Retired Engineer
just a WAG, but that sounds to me like a backlash adjustment is needed.
How's your steering overall?
explained here:
The sector gear is intentionally made with more play on either side of the center. This is because you only need that level of precision (no play) at the center when cruising straight ahead. Don't bother checking the play at any position other than centered.
Old Jeeper
Don
Absolutely! His pitman arm is connected to the problem though.
Rolie.
I will bet $ you know the difference 'tween Death Wobble and Bump Steer...when I had my shop I would get guys coming in thinking they had DW when it was on Bump Steer.
Carolina Jeeper
Rollie
North Carolina
Rolie.
Yes, I definitely know the difference.
Atom631
Atom631
Atom
New York
2021 JLUR
Rolie.
no death wooble or bump steer…yet. drives perfectly straight. in fact, I dont even have a stabilizer on for the past 100+ miles. can do 80 on highway with one hand.
so whats the verdict? new steering box? it is turning 38” ridge grapplers and I definitely feel it bound up hard in the rocks. can i use this as an excuse to go full PSC hydro assist? lol
Atom631
Atom631
Atom
New York
2021 JLUR
explained here:
i completely missed this post. i tried before to adjust the backlash bc the steering has been sloppy since the day I brought the jeep home. the adjustment screw on the JL is not a flathead. its an allen head and I could not for the life of me loosen it up. I was worried about stripping the bolt so I just abandoned trying to adjust it.
fwiw - I watched this video. .
failsafe306
Tulsa
2022 JLUR 2.0
Thanks for the video, I had no idea that was a thing.
Atom631
Atom631
Atom
New York
2021 JLUR
before you go messing with it, do some research. for the most part, everyone i spoke to that did this just made things worse. and both steersmarts and my local offroad shop advised against playing with it.
sherpaJL
Keystone State
2019 JLUR Mojito! ~ 2022 JLUR Hydro Blue
Fear not. I've made this adjustment.
Atom631
Atom631
Atom
New York
2021 JLUR
so I decided to replace the pitman nut with a a brand new factory one and torque to the 184 ft/lbs factory spec. I still had play. I then tightened it more and no change. took a closer look and its definitely the sector shaft moving. see video below. I decided to call PSC bc I had a question about their kits and I got to talking with the tech support guy and he said its totally normal for the factory box to have about 1/16” of play. which is basically what I have.
