Passenger side window will not go up!
jrghd3e
james
nj
13 Wrangler Unlimited Sahara
Sooo, my passenger side window is stuck in the down position. When I press the switch the motor makes noise for a second and then cuts off. I brought it to my local dealer and they said that the cable or something broke. The replacement part has to be shipped from Michigan and will not be in until next week sometime. Has anyone else had this issue?
Btw, my solution was to just take the doors off.
Jeepsterfreak
Honda, Future JLU
Windows? Did someone say windows? Who needs windows with the doors off?
xpsruler
2018 JL Wrangler Sport
Definitely check all your fuses to make sure they're seated. On multiple occasions members (myself included) have had something weird/an error which was resolved after finding multiple fuses which weren't fully seated.
jrghd3e
james
nj
It’s definitely the window motor.
W1ck3d
Toledo
2019 jl rubicon
Check the connections under the passenger seat make sure they are fully seated and push the wires in to make sure there wasnt a wire pulled out of the terminal..... You can also check the door check strap connection to make sure there is no bent pins from plugging and unplugging the connection... The trim piece is just held in by a few clips pops right out
