Drivers side rear window not working
392Rubicon
Todd
CT
2021 Rubicon 392
2021 392 with 27 miles. Decided to take top off for summer and realized my drivers side window does not go up or down from either front or rear window switch. Have tried the window lock switch and also unplugged door and plugged back in few times. Anyone else have a window that didn’t work?
Thank you
cOtter
Southern, Indiana
‘20 Sahara 2.0L Ocean Blue Metallic, Toyota Highlander & Pontiac G6 coupe
Senior Manager PM (Automotive OEM)
I would guess one of two items.
1. Blown / unseated fuse. But I am not sure without checking if multiple doors are on the same fuse.
2. If you have recently taken your doors off, there is a possibility that pints within the switch could have been bent. This is less likely, however, with the connection clips used for the rear doors. Very possible for the wire connector clips for the front doors.
jludave
The Isle of Long
IT Manager
Brand new Wrangler with 27 miles. Go back to the dealer. You have a warranty. This is what it is for.
