Part # for Transfer case fluid
GAJL
Drew
Evans, GA
2018 Jeep Wrangler Unlimited Sport
Does anyone have the MOPAR part # for the transfer case fluid for a Jeep Wrangler unlimited sport 3.6? I have been seeing 68218057AC and want to make sure I am correct. Thank for the help in advance from a Jeep rookie.
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
Valvoline Synthetic ATF+4 is what I do the deed with
You can also use Mopar ATF+4 Transmission Fluid. PN 68218057AC
Of course, there are other brands of ATF+4
Always be sure you can loosen the fill plug before you remove the drain plug.
You will need a hand pump to get the fluid in with.
https://www.amazon.com/gp/product/B07DTS8N7P/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Use yellow Teflon tape on the fill and drain plug.
Do know that you have a skid plate that will be in the way when you go to drain the transfer case...
Some guys/gals will pull the skid plate,(and chance breaking a skid plate bolt) but it is far easier, to fashion something like below to facilitate draining..
You place this between the drain hole and the skid plate.... you pull the plug and the fluid runs along it, and then into the drain pan. No big mess on the skid plate and no pulling the skid plate.
This is an aluminum foil pan you get at the dollar store, etc.. You just cut the shape and fold up the edges. It's about say 16" long and about 4-5 inches wide. Easily cleaned when you get done so you have for next time..
Jeep Wrangler JL Part # for Transfer case fluid 20210115_193745
bobholthaus
Bob
St. Louis, MO
2023 JKURD AEV JL370; 2014 GC Overland Diesel
Technology Integrator
How many quarts do I need? And what pump should I use for the Mopar ATF+4? Thanks guys.
