PAC Audio / Stinger Heigh10 / MB Quart - Audio Interference
ELJL
Ed
Fairfax, VA
22 Wrangler Unlimited Rubicon
you would think so, i even ran the amp ground and power cable to an oem battery outside the jeep so the power cable and grounds could hopefully be taken out of the mix, i still received feedback. its almost as if the pac audio devices share some similar power/bcm connections in the dash somewhere and the sound traverses the headunit's RCA outs.
Well youre on the right path then. 👍🏼
GoetxC
MN
22JL
Any chance a fix was found for this issue? I'm dealing with the same issue. Heated steering wheel only though - works fine with the heated seats on.
