Oil life Not Resetting?
SimpleAce
Tyler
Denver, CO
2020 JLUR
So I brought my 2020 to the dealer to change my oil about a month ago and 400 miles ago. After I got it back that day it was not reset back to 100 percent. So I held the "ok" button to reset it and it went back to 100 percent.
Fast forward to today I noticed that it is still at 100 percent oil. Is that possible even after driving 400-500 miles after resetting?
Thanks, everyone! Pic of the bae!
Jeep Wrangler JL Oil life Not Resetting? 92262435_1546265268857811_6528785778128977920_o
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
@SimpleAce
IF you are concerned just do another RESET. Won't hurt to do so since you have only driven 400 miles... Also, I sure hope you do not rely on that oil life monitor.... I would not..
By the way, there is more then way to reset the Oil Life ... not sure if you already know...
Oil Life Reset:
1. Without pushing the brake pedal, push and release the
ENGINE START/STOP button and place the ignition to
the ON/RUN position (do not start the engine).
2. Navigate to Oil Life submenu in Vehicle Info in the
instrument cluster display.
3. Push and hold the OK button until the gauge resets to
100%.
Secondary Method For Oil Life Reset:
2. Fully press the accelerator pedal, slowly, three times
within ten seconds.
3. Without pushing the brake pedal, push and release the
ENGINE START/STOP button once to return the ignition
to the OFF/LOCK position.
NOTE: If the indicator message illuminates when you
start the vehicle, the oil change indicator system did not
reset. If necessary, repeat this procedure.
SimpleAce
SimpleAce
Tyler
Denver, CO
2020 JLUR
No, I track my mileage in a word document, I was just curious is all. It finally dropped today after I drove another 100 miles or so. Thanks, guys!
