Uhdinator
My first jeep (YJ) in 1989 had 3:08 gears, no lockers, no traction control and had something like 28" tires and a soft top. Buried it a few times then learned a lot, eventually lifted it 3-4" just to fit 33" tires.
My second Jeep, The first Rubicon in 2003 didn't have sway bar disconnects and stock tires were barely 31". Lifted it 2.5" to fit 285's (33") tires. It had much better capability with a rear limited slip in 2wd or 4wd and the lockers of course in 4W lo which I rarely used. It had no traction control.
My current Jeep is a Sport 2dr with no lockers or limited slip but it has traction control that is close to having lockers in both axles that works in 2wd, 4wd and 4wd lo. It's not going to be doing extreme rock crawling a lot.
Point being the JL has come a long way since I started jeepin. It's gotten a lot better in ground clearance and ability to upgrade to a bit larger tire without major modifications of a any stock Jeep i've owned. With a 2" spacer lift and a modest size tire like a 285/70 or 295/70 you won't kill your ride comfort an improve ground clearance. Even just upgrading 1 tire size larger with an all terrain or more aggressive mud tire makes a difference. Terrain that used to scare me in my first jeep, i don't blink and eye at in my new Jeep. I never broke or dented/damaged anything on any of my jeeps and wheeled them with a light foot as they were my daily drivers, and had a lot of fun doing it.
