No screen or camera.
Storman
Norm
2021 Rubicon
My Rubicon did not recognize my key fob and had to jump start it. No back up camera and blank screen now. My aux battery has been disconnected for a while and regular battery is fairly new. Any ideas.
alphawolff
california
2021 JLU
Radio screen/backup camera is because of the low battery voltage causing it to lose its configuration. It'll fix itself after a sleep cycle or two.
If your aux is properly deleted and you needed to jump start then your primary is probably just going bad. Make sure you're not using stop/start
NoneTheWiser
Brent
Santa Fe, New Mexico
2023 2 Door Rubicon, 2023 Rubicon 4xe.
I've seen something similar twice in the last month. I go out to start my Jeep (2023 Rubicon 2 door ~2000 miles) and nothing happens. Use key to unlock the door, and everything is dead. Pop the hood to check battery voltage, and it reads ~13V. WTF?!?!. Drop the hood, and now everything works... After the second occurance of this problem, I reseated all the fuses and am waiting to see if the problem has gone away. I reseated all the fuses when I took delivery, so maybe some have worked themselves loose?
