Need 2 door measurement help
JA50N
Jason
Suffolk, Va
2023 Wrangler 2 door
I just installed a bumper and winch on my 2 door Willys and I didn't take any height measurements before I installed them. Can somebody with a stock suspension sport or Willys take a measurement just behind the front fender flare to the pinch weld or rock rail and the same measurement just in front of the rear fender flare? All I am looking for is the stock rake to compare to my current one. It doesn't matter what tires you have as I am just looking for the difference in the 2 measurements. Just needs to have stock suspension and no added weight in the front or rear.
Dgr401
Dennis
Rhode Island
2020 Wrangler JL Sport S - Granite Crystal
I have side steps on my Sport S and the ends of the steps are under the fender flares where you would like the measurements. Is there another spot that would be useful for your needs?
JA50N
Jason
Suffolk, Va
Bottom of the frame as far forward as you can before it starts turning up and the bottom of the frame back by the rear body mount will work as well.
Dgr401
Dennis
Rhode Island
This is what I came up with.
Front - 11.75 inches
Rear - 18.75 inches
JA50N
Jason
Suffolk, Va
That seems off. 7” difference. I was expecting 1” at most.
Dgr401
Dennis
Rhode Island
I guess I was in the wrong spot for the rear. My wife has the JL right now, will check later this afternoon.
Dgr401
Dennis
Rhode Island
take a measurement just behind the front fender flare to the pinch weld or rock rail and the same measurement just in front of the rear fender weight in the front or rear.
I was able to get the measurements at the pinch weld. They are pretty close.
Front - 15.5 inches
Rear - 15.25 inches
Hope this helps.
JA50N
Jason
Suffolk, Va
Front - 15.5 inches
Rear - 15.25 inches
Hope this helps.
That helps a lot. Thanks
Dgr401
Dennis
Rhode Island
Was there much of a difference after adding the bumper and winch?
JA50N
Jason
Suffolk, Va
Gonna check if it ever stops raining here.
JA50N
Jason
Suffolk, Va
Looks like about 1/2” difference with the front lower. I aslo have my back seat removed so that is probably contributing to it some.
J.C.
J.C.
East Cobb, GA
2023 Willy's Sport
I haven't gotten my 2 door Willy's Sport yet, hopefully this week or next it will arrive. I was anticipating around .75" with a bumper and winch, but I went ahead and bought spacers just in case.
