My First 10,000 Miles
JoeValkIS
Arnold, MO
2018 Wrangler Rubicon, 2019 Can Am Spyder F3T
I just wanted to post this for the folks that might have been missing me. This morning, I turned over 10,000 miles on my '18 JL Rubicon. Almost every one of the miles have been happy ones. While I haven't had the mechanical issues that some of the others have had, I have chased a few gremlins and have my problems with it. I have also had a lot of fun in it.
Putting the order/build issues behind us (information about that is in my signature below), my issues have been a few glitches with the radio...like losing Android Auto...completely...until the next day...and Frame Bolt issues. I will get to those later in this post.
The good...first off...for me...was the looks of it. It is a stunner and I get complimented on it often. And she is damn near bone stock.
Jeep Wrangler JL My First 10,000 Miles Glamor_Shot
The performance is surprising. Yes, first gear is geared low...it is a Rubicon with 4.10 gears. But I didn't buy this thing for speed...I bought it because it was capable. I have had the chance to take it off-roading a few times in her first 10,000 miles. The first time was a forest service road in Arkansas. It wasn't nothing that I needed 4-wheel drive for but it was nice to have it.
Jeep Wrangler JL My First 10,000 Miles First_Off-Road
Next, I took it to an off-road park west of St. Louis.
Jeep Wrangler JL My First 10,000 Miles Second_Off-Road
The last time was another off-road park south of St. Louis.
I also sustained my first damage at this off-road park. While trying to climb up a small rock ledge, I didn't have enough momentum to hop up the rocks. Unfortunately, there was a tree right behind me and when I let off the clutch to try to get another go at it, I tapped the tree and broke my taillight lens. That will be a $350 oops when I replace the light. (side note...if ANYONE has a LED tailight without the side sensor that you don't want...drop me a private message. I don't want to pay $350 but will entertain what you think it is worth.)
Jeep Wrangler JL My First 10,000 Miles First_Damag
While on our trip in Arkansas...I had our first "OH F*CK" moment.
From the video, I was able to get the truck information and I called the dispatcher. I also sent them the video showing the truck clearly over the line on a 2-lane road. I doubt anything had been done about it but I tried.
It hasn't been all positive. I have the Rubicon Drift (or maybe it is the Wrangler drift) but I haven't asked my dealership to look at it yet. Next oil change, I will ask them to look at it and I am sure they will tell me it is within specs. Hopefully, the salesmen I dealt with can put a little pressure on them to try to fix it.
The biggest problem I have had is attempting to put Step Rails on it. I purchased a set of ACE Engineering Rock Rails and went to remove the first body bolt and I broke it off. Contacted my dealership and they ordered a new bolt and set up a date to remove the broken one. While they had it, I had asked them to install my steps. Well, the steps are still sitting in my garage and are not on my JL. They could not remove the other bolts. I have tried a couple of times to remove the other bolts but can't get them to move very much. I haven't tried heat but I think that is my next move. If that doesn't work...I will find an independent shop that will break the bolts, remove the broken bits, and install my steps with new bolts.
Overall, I am VERY pleased with my JL. It is everything that I have wanted in a Wrangler. It gives me a pretty good ride, handles off-roading very well, and even gives me decent gas mileage. On that topic, I have been getting 18-20 mpg with my mixed driving. A few weeks ago, I got 23 mpg just cruising around back roads keeping it in 4th gear running 45 mph. It has taken Monica and I on quite a few adventures and I am looking forward to many more adventures in the future.
Sorry this is so long...Hope you enjoyed reading it.
P.S. If the videos don't work for you, let me know and I will post again.
ZEN357
Pittsburgh, PA
Jeep Grand Cherokee SRT
Auto Mechanic
I love the color scheme. Graphite w/red trim. Looks awesome!!!!
RubiZ
Canada
2019 JLUR
Great write up in detail. Thanks for sharing you 10K experience
BlackRook
Ross
North Jersey
2019 Mojito! JLUR
SCIENCE!
Haha, that truck... When driving on two lane highways in NJ, driving past a truck over the line like that is called "driving past a truck." As in, they all do that. It seems like there's a consensus that running some poor person off the road is preferable to slowing down slightly going in to curves. Though, in fairness, everybody tailgates here, so if a big rig were to slow down he'd be immediately rear ended. Regardless, makes me really glad I don't have steering issues...
Those body bolts are tricky beasts. I used a 12" breaker bar, worked really well. Getting those bolts loose was a whole body exercise, however the shorter breaker bar prevented me from getting too much torque on the bolts. They loosened up nicely after about 2-3 minutes of me cursing at them.
Anyhow, looks like you've been using your Jeep the right way: by enjoying every mile! Thanks for the post!
Sean L
Sean
North Carolina
I just hit 10,000 in My Jeep last night. Going strong Joe!
JoeValkIS
JoeValkIS
Arnold, MO
So...you got more miles than posts now!! LOL Congrats!
Sean L
Sean
North Carolina
IPvFletch
Kevin
ATX
JLUSS
In the end, what worked for mine, was sheer brute force. Just get a longer breaker bar, or find someone with bigger muscles. A local Jeep shop helped me when I couldn't get any further (and then made me look like a big wuss after he got them off in just a few minutes).
The rears/middles were cake on mine. Just blue loctite. Only the fronts have red on them. Also be sure to clean out the threads real good once you get them out, or use new bolts.
JoeValkIS
JoeValkIS
Arnold, MO
Yeah...that is what broke the first front bolt...brute force. I even got my impact after it got stuck to try to loosen it up and it wouldn't budge (in or out) any more until it broke loose with my breaker bar. When I last tried the rear bolts, I couldn't even get them to budge at all. After breaking the front one...I am scared of breaking another one. I may just have to buck up and pay a local 4x4 shop to put them on for me.
Pic18
RI
2018 Mojito JLUR, 2017 Grand Cherokee Trailhawk (my wife’s)
@JoeValkIS
Do you have the 4cyl? I have an unlimited 6cyl and my avg mpg is 16.1 for my first 4900 miles.
JoeValkIS
JoeValkIS
Arnold, MO
@JoeValkIS
Nope...2-Door Manual 3.6L Rubicon for me. When I rode the trails on Sunday, I got 16mpg. Usually on my drive to/from work, I am getting right at 20mpg...Best I have gotten on a tank of gas is 23mpg.
IPvFletch
Kevin
ATX
JLUSS
Yeah, I guess brute force and dumb luck then. Damn. I guess I got some good luck, somehow. Even when I was certain it was going to break.
