Making lights flash
flick2614
Randy
AZ
2021 Jeep JLU Rubicon Diesel
I'm seeing all these UTV's out here with front facing lights flashing; I have to guess these have some kind of modulators added in line. Considering all the dust on the AZ trails and the heavy traffic I'd love to have the option to make my front, amber light bar flash. Has anyone pulled off something like this?
gek
Code Monkey
Jeep Wrangler JL Making lights flash 1780943766130-pv
I think this button would work well enough and be less annoying
gek
Code Monkey
flick2614
flick2614
Randy
AZ
I’m using my Tazer’s light show! I wired in my aux lights as well
That's not a bad option. Can the tazer be programmed to just flash one of the factory aux switches?
Terrymo
Terry
2023 JLURXR 3.6 ET
gek
Code Monkey
flick2614
flick2614
Randy
AZ
I have wig wags on the back for dusty conditions. But FFS please don’t start driving around like UTVs causing epileptic seizures in photo sensitive folks. I used this module.
https://www.amazon.com/dp/B099NJVQX9?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1
@yokramer deals with this stuff at work so probably has the best info
Just one, 20" light bar is all I'm planning to flash. Not wanting to be seen not looking like some mobile disco out here. That will attract the wrong crowd.
gek
Code Monkey
Jeep Wrangler JL Making lights flash {filename}
I'm not sure Grayhound is quite there yet ... but he's closer than he should be. :)
ORACLElights
Peak Sponsor (Level 2)
Metairie, LA
www.oraclelights.com
2019 Jeep Wrangler JL
Automotive LED Manufacturing
If you're looking to add a flash/strobe function to auxiliary lighting, another option worth looking at is the TRIGGER systems.
Both the TRIGGER 4 Plus and TRIGGER Six-Shooter support a flash/strobe function through the TRIGGER ACS Plus app, along with standard on/off control, dimming, and momentary switch functions for compatible lighting. It's a nice solution if you're already planning auxiliary lights and want wireless control without adding a bunch of extra switches in the cab.
We've used them quite a bit with rock lights, grille lights, chase lights, and auxiliary lighting setups where customers want a little more functionality than a traditional switch panel offers. The app-controlled flash feature can be especially handy for off-road, trail, and event use.
yokramer
Snark Incarnate
flick2614
flick2614
Randy
AZ
The Trigger looks to be a good system and solution however I'm looking to make a $200, 20" lightbar flash so may be a little over the top for the application. Does Oracle make any type of inline modulator or anything like that?
