Loud shifting noise
MMerlinb
Tony
ny
2025 JLU
Solved about 90% of my problem. I realize that when I first got the jeep, I was still figuring out where the best shift spots were and where the clutch engagement was. So I wasn’t hearing the noise because of that. Once I got used to everything and where I needed to shift at and all that I started shifting quickly I would shift into gear let off the clutch. Now I’m revving up to 3000 to 3500 RPM before beginning to shift once the engine is revved, I clutch, shift very little noise by the way if any, and then instead of just releasing the clutch, I release a half a second to a full second slower, smooth no more problem no more noise. Or almost no more noise. Sounds like I was the issue along lol just thought I’d share. At least that’s one issue solved lol
Reflektr
Travis
Illinois
2025 JLU Willys
Equipment mechanic
Good deal. Glad you got it covered. I also found that higher rpm’s seem to help in the lower gears. On mine it seems like you really gotta give it the groceries, then granny-shift like you’re driving an old C7500 Grain Truck if you want a nice smooth transition. Could just be the 4.10 gears though. Everywhere I go it seems like someone’s always tailgating me until I get beyond 3rd gear. Ahhh the joys and curses of driving a manual transmission in a modern world lol.
