3TV
- Jan 7, 2018
- Southwest USA
- 2022 JLUR 392, 2025 JLR
I'm still in the process of piecing together a build on a 2-door JLR I ordered and need help deciding between suspension lift and lift provided by portal axles. Portals from 74 Weld are $20K, and they provide 3.8" lift, 4" additional width per side, and a 22% gear reduction. But they don't finish the job as well as you might think. I'm planning on 38x13.50R17 tires, so to do it right I would also want to add Metalcloak Baller ball joints, Metalcloak tie rod and drag link, and adjustable King 2.5 shocks for a 0"-2.5" lift. That brings the total cost to $25K. Compare that to a Metalcloak 3.5" lift with the same ball joints, HD steering, front driveshaft, and Metalcloak Black shocks, at $9K. So, what makes the portals worth the extra $16K? 3.8" more clearance under the axle might be worth that for a dedicated trail rig. My JLR won't be a "dedicated" trail rig. It will be towed, sometimes on a trailer and sometimes flat towed with a tow bar, all over the country. It will need to be reliable when 50 miles from pavement and all alone midway between Moab and the southern Canyonlands NP, or on the Rubicon Trail by myself, etc.
How much more maintenance do portals need? How big of a deal is it to change gear oil in the portals every 5,000 miles? What wear items are there? How many miles can someone expect to get out of them? Are they something that can have the gears, bearings, and seals flown in and be rebuilt in Timbuktu (city in Mali), or when exploring the Philip Smith mountains in northern Alaska, if needed?
