LED turn sign recommendations
amoebadrop
New York
2019 wrangler
I have tried a couple of different switchBack turn signals, both with a built in canbus so I didn’t have to mess with a resistor. I am completely unhappy with both, they are nowhere near as bright as my after market LED headlights and fog lights - I’d actually probably rather just use the OEM amber bulbs at this point.
So my question for you guys is can you provide recommendations for decent switchbacks, even if I need a resistor. Basically all I’m looking for is an OEM LED brightness/look!
MauiSteve
Stephen Rodgers
2021 Rubicon 2 door, 2018 Colorado ZR2, 2009 Honda Ruckus, 1973 Honda CB750
Mostly retired
I just put Lasfit headlight bulbs in my 21 JLR and headlights and reverse lights in my 18 Colorado ZR2. All is working very well so far, no complaints. Headlight performance is much better than stock halogens which in both cases was pretty poor.
jmccorm
Josh
Tulsa, OK
2021 JLUR
Systems Engineering
OPTION 1:
Replace your incandescent turn signal bulbs with LED bulbs:
https://www.amazon.com/gp/product/B07H6TDYZR/
Option #1 is best attempted with a 2021+ Wrangler (I believe) since they're less grumpy about having the LED bulbs swapped in without using JScan or some other tool to tell your computer about it. The newer models just take it in stride.
OPTION 2:
Replace your turn signal assembly with something that has more style:
https://www.amazon.com/gp/product/B0BDKS8FFD/
Option #2 is made specifically for the halogen base configuration.
Both routes are within the realm of light-duty DIY work. I didn't have a problem with either one on a 2021 JLUR.
sailscall
Buffalo, NY
2021 2dr Sport 6MT
ScouterJames
Langley BC Canada
2022 Wrangler JL Willy's 2 door
If you have a Sahara or Rubicon with two bulbs in the fender @jmmcorm is spot on. If you have a Sport or Sport S with a single bulb in the fender, you'll need the 7443CK. I use the Lasfit's. They look exactly like the Oracle's but for less $.
Amazon.com: LASFIT 7443CK LED Bulb 7444CK ONLY for CK socket, Switchback Yellow/White, CANBUS LED Turn Signal Light Error Free Anti Blinker Bulb Hyper Flash(2pcs) : Automotive
Not a fan of the LASFIT (or any other without a forward facing diode). The dark spot these bulbs leave is an OCD nightmare LOL
Speed331
Sean
Las Vegas, NV
2008 Jetta, 2018 Discovery Sport, 2020 Wrangler Sport S (on order)
Honestly, it's barely visible. I'v had both the Oracle and the LASFIT. Can't tell the difference and the amber signal is crazy bright.
Jeep Wrangler JL LED turn sign recommendations 20240415_192803
Jeep Wrangler JL LED turn sign recommendations 20200825_170320
grevyi
Jacob
GA
2024 Jeep Wrangler Sport S
Did you have to add any resistors for these to not get warnings? Did you have to code anything in the ECU?
Speed331
Sean
Las Vegas, NV
Nope. They were straight plug and play. Been a few years now with no issues.
grevyi
Jacob
GA
Do you have the exact part number you installed? I would appreciate!
Speed331
Sean
Las Vegas, NV
ORACLElights
Peak Sponsor (Level 2)
Metairie, LA
www.oraclelights.com
2019 Jeep Wrangler JL
Automotive LED Manufacturing
We're more than happy to help if you have any questions regarding our turn signal LEDs!
