Land Anchor for Snow
treillw
Montana
Jeep Grand Cherokee
I often find myself driving around alone on the prairie, 20 miles from the nearest house, in a lot of snow when it's 20 below zero. I'd like to get a land anchor to get myself out of the snow drifts. No trees around to winch off of.
Any recommendations on one? I've watched a few pull pal videos and they look good. Any that work better for my application or store away better?
It would be a plus if I could mount it on the outside of the Jeep, as I typically have the inside filled with junk. Any that mount up well to a tire carrier or elsewhere?
I'm also in the market for a rear tire carrier. Considering the Teraflex and the Warn carrier attached to their elite bumper. Dunno if one of those is better suited. I could also see myself wanting to mount some water/fuel roto jugs.
Thanks!
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
It sounds like you're describing a part that's already on your vehicle. Take a walk around to the back and look at the thing hanging on your tire carrier. That's a land anchor for snow.
treillw
Montana
Jeep Grand Cherokee
Again, too much digging.
GtX
Illinois
2020 JLUR 3.0D
Working for the man.
treillw
Montana
Jeep Grand Cherokee
No problem if they are covered in snow.
Umm. But, tracks!
Could get a couple of nice snow mobiles for that... but the jeep might be more fun and enjoyable to be inside!
  • Like
Reactions: GtX
Tech Tim
Summit Sponsor (Level 3)
Tim
Poulsbo, WA
4x4 of all kinds
The Pull-Pal is a great tool, have used one for many years. Snow, sand, mud, dirt, it works great when you have nothing else to anchor to.
They'll pull right through really soft snow, until they get down and anchor to something substantial.
One tip is to tie a rope on the back end of it, so you can easily pull it back up and out once you are done with your recovery.
This is the one I use:
https://www.northridge4x4.com/part/winch-accessories/pp11-premier-power-welder-pull-pal-rw11000
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
I know you mentioned that a couple times. How do you expect to be "anchored" without digging? You could tie off to something that sits on top of the snow, but I don't think that would be much of an anchor.
RocknJL
Idaho
2020 JLURD
Second the Pull Pal used to use one all the time in college playing with my square body suburban and a winch. Works awesome and easy to use. Only downsides are its large (about the size of a highlift) and you may have to dig it out after a recovery.
