FFM069
- Oct 19, 2020
- Ottawa, Canada
- 2020 Jeep Wrangler Sahara
Hi everyone,
I just recently changed tires on my JLU Sahara and went from 265/70R18 Falken Wildpeaks to 275/70R18 Duratracs. I also installed Spidertrax wheelspacers at the same time.
I noticed that on my first drive on the highway it would not shift into 8th gear at all and mostly stay in 6th gear (it would occasionally hit 7th gear). Fuel consumption also went down by like 2-3 mpg. I am a little surprised given that both tires are more or less a 33inch tire so I would have never guessed that big of a difference.
My question is will the transmission eventually adapt and shift into 8th gear again (because it's a learning transmission)? I did not recalibrate for the new tire size as the old one was almost the same (although I also did not recalibrate the tire size when I went from the stock tires to the Wildpeaks).
Should I simply wait and drive a bit more and see if the transmission adjusts? Or is it recommended to recalibrate the Jeep for 33 inch tires? Again, I am surprised because with the 265/70R18 Wildpeaks I would hit 8th gear on the highway all the time and now I am in 6th with only marginally larger tires...
Any help, thoughts or general advice is as always much appreciated fellow Jeepers!
