JLU Pulling To Right
kburns
Kris
Delaware
2019 Jeep Wrangler Sport 4 Door
HI, my 2019 JLU has been pulling to the right and is starting to annoy me. I took it in for an alignment, they aligned it and it is steering a little better however it still pulls to the right all of the time. I have attached the alignment chart, does anything look off? Does anyone have any suggestions ?
Jeep specs: 285, 75 17 KO2's and Rubicon take off suspension. (Springs, Shocks and front control arms. )
Thank You
Kris
Jeep Wrangler JL JLU Pulling To Right 20210920_204318
Fonzilla85
Fonz
Ventura County, CA
2018 Jeep Wrangler JL Rubicon Unlimited
Lawman
Some forum members have mentioned having that similar issue. Some items that have been mentioned as a cause are tire pressure and the steering dampener. Hope this helps.
kburns
Kris
Delaware
Common issue. Solid axle, roads slope to right for drainage. I haven't had a jeep that doesn't pull this way.
Im used to my TJ which does not pull like this. I guess because its heavier it pulls more.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
FYI, the mopar lift LCAs are only $60 for the pair and should help get your caster in line.
JimLee
Jim
Too damn close to Death Valley
'19 JLU
Getting your passenger side caster .1 to .3 degrees higher than your drivers side helps with road crown pull (yours is the exact opposite) , but you need adjustable control arms to do that.
