JL Adventure Series Mid Width Front Bumper
NextDan
Peak Sponsor (Level 2)
Grand Junction , Colorado
www.nextventuremotorsports.com
1949 Willys VJ, 1973 Jeep Commando, 18 JL , 21 JT
CAD Designer, Adventure Machine Outfitter
This is our mid-width front bumper built to match the high clearance angles and styling of our adventure series rear bumpers!
These bumpers are crafted from a combination of 1/4", 3/16" and 1" thick steel (for the machined d-ring tabs of course!) to give your Jeep the light weight, but stout-where-it-counts bumper it deserves! The machined recovery tabs are welded to the winch plate of this bumper which is bolted directly to the frame rails.
The internal tray/winch plate is a single piece of 1/4" steel has been laser cut and precisely CNC formed. This tray will accept all width's of the NV Adventures Series Front Bumpers if you decide to try a different width bumper in the future. The winch tray locates the winch between the JL framerails for unimpeded airflow to the radiator, and a lower center of gravity vs winch mounts above the frame rails.
Optional Winch Delete Tray can be optioned as stainless steel, or 1/8" mild steel. This is recommended for a "complete look" if opting to run the bumper without a winch.
Light provisions are designed for a 3x3 LED Cube. Winch Tray will accept a Warn Xeon series*, Warn M8000, and other similar sized winches. Some minor trimming may be required on the Jeep's framehorns to fit the larger Xeon series winch.
Bumper is shipped bare metal unless ordered with powder coat. Bare metal products may have scratches/surface imperfections from raw material handling/manufacturing/fabrication that are easily covered up with a textured powder coat. Additional finishing/sanding/prep work will likely be required if you wish to have them finished in a smooth coat or paint.
EST. SHIPPING DATE OF OCT 1.
https://www.nextventuremotorsports.com/product/jl-mwfrontbumper10/
