- CavFab
- May 9, 2018
- Wildwood ga
- 2018 jlur
- Occupation
- Aftermarket Jeep Product Manufacturer
The Mid width predator bumper provides great most while maintain exceptional ground clearance and departure angles. Modeled from our Crawler Full Width rear bumper, this is a slightly less wide design that stops at the corners fo the tub. 8 mounting points secure the bumper to the frame to give you a solid recovery point. Sleek high clearance design with a center cutout for carrying a larger tire.
**This bumper is also elidible for our JLForum Discount! (Code: JLFORUM)
https://www.cavfab.com/Jeep-Wrangler-JLJLU-Crawler-Series-MID-Width-Rear-Bumper_p_373.html
- Designed, Engineered, Tested, and Built in the USA
- Constructed of 3/16" CNC Cut / Formed American Steel
- Fully welded and finished
- Bolt on design with 8 mounting points
- Included D Ring Shackle Mounts
- Ships Raw Steel
- Compatible with factory style hitch
- Compatible with factory backup sensors
