Jeep Freedom panel alignment
dmgarcia2197
Miguel
Ohio
2023 Jeep Wrangler Rubicon
I just got my rubicon 4 door. I noticed that the freedom panel are misaligned. Wondering if any of you have the same issue. No leaking or anything.
Jeep Wrangler JL Jeep Freedom panel alignment 4C82CEA3-A9B0-4F00-A88A-D6283412C0E0
Jeep Wrangler JL Jeep Freedom panel alignment 5FB8924E-B092-4A20-997A-A037E0BF92A1
Jeep Wrangler JL Jeep Freedom panel alignment A863A1F5-4DC7-4037-B7E0-C733A26DCAD6
Maverick909
I.E.
just pop the handles loose push it back and close the handles
KeithF
Central Va
2021 Wrangler 80th Anniversary
it wont leak like that, but I realign mine when I switch from my Sunrider to the freedom panels, loosen the screws on the handles line everything up then tighten the screws back down. There are alignment pins in each handle that may need to be moved to get enough movement to get them straight.
I assume the fabric in my Sunrider wasnt installed "perfectly" causing it to close differently than the Freedom panels, it doesnt really matter but after having installed a few soft tops on sports cars I like things to line up........
dmgarcia2197
Miguel
Ohio
Do you mind sending me picture of those adjustable screws? Thank you in advance
KeithF
Central Va
this shows the 2 screws on each latch and the pin on the Freedom Panel. By moving the latch on the header you move the hole for the locating pin. You can also use the tool in the included Jeep tool kit.
Jeep Wrangler JL Jeep Freedom panel alignment top latch
dmgarcia2197
Miguel
Ohio
Thank you man! Is this the only screws I need to loosen to adjust the panels?
Wondering if you have videos to help too. I appreciate it!
dmgarcia2197
Miguel
Ohio
Did you adjust the screws for the latches too?
Byrds8
Mine are misaligned like this also. Guess I may adjust them also. Question is though, should they match the more forward or more rearward one?
dmgarcia2197
Miguel
Ohio
Thats the same question i have too! I would assume that the driver side needs to be adjusted since its the one getting removed first. Do you have pics of yours?
dmgarcia2197
Miguel
Ohio
Just loosen those 2 screws i have the arrows pointing at on each latch, just enough for it to move, then align the tops how you want them then tighten them back again.
I appreciate your help man! My Ocd is killing me every time i see it ?
Byrds8
I do not have images of mine. My wife's is the same way. After I noticed mine like that, I went and looked at hers. When hers was the same I assumed it was meant to be that way and ignored it til I saw this post.
KeithF
Central Va
Adjust both sides, loosen the screws on both sides and leave the freedom panels loose/unlatched so you can move them around until the gaps are straight, then tighten the 4 screws . It likely both panels are misaligned.
Byrds8
So it’s not going to matter where on those seals they sit?
