Is this normal? Exposed wiring
Amciano
Anna
Rhode Island
2024 wrangler sahara
After owning my 24 sahara for over 1 yr i just noticed this exposed wiring area when u open your rear window and look to left...should this have a cover over it?
Terrymo
Terry
2023 JLURXR 3.6 ET
The harness itself looks similar to my 23 but mine has a black plastic shroud and the interior wall of the hardtop is molded differently. If you are concerned I think I would raise the harness a little further up into the hole so the exposed wires are farther away from the edge of the hole in the hardtop that the wiring passes through, then use a Velcro tie wrap to hold in place. The other 2 wire harness in my pic is not OEM.
Jeep Wrangler JL Is this normal? Exposed wiring IMG_4206
Jeep Wrangler JL Is this normal? Exposed wiring IMG_1325
Amciano
Amciano
Anna
Rhode Island
Do u think it dropped down from the opening? Ill check other jeeps anyone send me a photo of theirs
Terrymo
Terry
2023 JLURXR 3.6 ET
I’m not sure, it needs to be low enough to easily disconnect it to remove the top. Hopefully others with 24 or later can answer.
KIZEMAN
LAKEVILLE MN
'21 4xe High Altitude - '18 Range Rover Sport SVR
I wouldn't say it's abnormal or concerning. You want to be cautious when removing the top and disconnecting the harness.
My design is a bit different but the upper connection clicks into a bracket to keep the wires higher in the housing. Maybe check to see if you can click it in a bit higher.
Jeep Wrangler JL Is this normal? Exposed wiring 20251015_115721
Nitehawk92
Vandalia, Ohio
23 JLU Reign Rubicon 14 Mazda, 22 Hyundia Santa Fe
Retired Air Force Current Civil Service Civilian.
Here is what mine looks like...
Amciano
Amciano
Anna
Rhode Island
I have sky one touch roof so would never remove a hard top i think im missing a cover perhaps
KIZEMAN
LAKEVILLE MN
I'll bet there is a click in piece up a little higher. I can disengage the red tab and pull the bottom of the harness without holding the upper harness connection with the wires that are protruding in your picture.
Amciano
Amciano
Anna
Rhode Island
Thanks for info.ill play with it can someone with sky one touch roof 24 sahara send a photo?
Amciano
Amciano
Anna
Rhode Island
I tried moving it up.it's solid doesn't move guess that's the way it is all exposed wiring..
Terrymo
Terry
2023 JLURXR 3.6 ET
Sky One Touch changes things it appears. Earlier model but check the video at about the 6 minute mark. Looks like because the SOT top is molded differently in that area the black shroud is different and yours may be missing, Blurry screen shots from the video
Jeep Wrangler JL Is this normal? Exposed wiring IMG_4207
Jeep Wrangler JL Is this normal? Exposed wiring IMG_4209
