Intermitant start for 2019 Rubicon...
Petesjeepforum
Hildebrand
Haverhill MA
2019 Wrangler Rubicon
So sometimes my 2019 Rubicon doesn't start the 1st time.
I step on the break and hit the start button, and "click" that's it.
I have to try numerous times with each time being a different time to start, but it does eventually start.
I checked the battery and it's 14 volt, so it's not the battery.
Any thoughts?
Reinen
Utah
2021 Jeep Wrangler JL Rubicon
The battery should only be 14v while it's getting charged. That's a red flag. Also batteries can produce a fully charged voltage but do not have anywhere near enough CCAs to start an engine.
It's almost certainly your battery, or batteries if you have a Main/Aux. Always replace both at the same time or you will go through batteries much faster than you should.
Petesjeepforum
Hildebrand
Haverhill MA
I brought it into the dealership and they didn't find any codes.
I agree with you it maybe the starter.
The battery is fine so I know it's not the battery.
Thanks.
DavidES1
Tucson
2023 Jeep wrangler rubicon
brake switch maybe going out. Try pressing harder
GabeBoyTheGreat
Virginia
2018 JL Sport, 2025 JLU Willys
Test Engineer
PT's19Rubi
Paul
NC - Just across river from Uwharrie trails
2019 Rubicon 2D, 3.6, 8A
Retired Electrical Design Engineer
David beat me to the brake switch. The clutch switch on a manual, or neutral switch on an automatic can get flakey also. Try pushing the clutch pedal farther down, or try neutral instead of Park.
