How to determine crawl ratio?
DavidArmen
Los Angeles, CA
2021 JLUR
Not to nitpick but I see this all the time. A higher numerical value = lower gear. 100:1 crawl ratio is lower than 50:1. I added lower (5.13) gears to my rubicon (factory 4.10 ratio). I know it’s semantics but this is confusing enough for most people without twisting terms around.
Thank you but yes it is semantics. The OP understands what I am saying.
Chocolate Thunder
Jeremy
I completely understand what he said and meant and I think most people do. I don’t see either way of stating it as incorrect. There are numerous ways to refer to gear ratios. Taller or shorter. Deeper or shallower. Bigger or smaller. Higher or lower. As long as good context is given, which he did in detail, there shouldn’t be confusion.
So yeah, it’s only semantics and not confusing at all. You seemed to understand it too.
AZRubicon
Arizona
www.youtube.com
2020 Rubicon Unlimited
Best tool I have found to determine what you have and what happens when you tweak: https://www.crawlpedia.com/calculators.htm
J0E
J0e
Hawaii, MT, SLC, NYC
bt39.com
2021 JLR, 05 LJR on 43s
