Hi Brian,Benny, thanks for all you do! I have a 2024 4xe Sport S (with the M220 WT rear and M210 WT front) and was wanting to install regular OEM e-lockers in the (currently) open diffs. Are they a bolt in using the existing axle shafts? Or is there an offset in the carrier which forces me to use different length axles? Thanks for any info!!
I would need your VIN please so that I can compare the axle housing part numbers to see if they are the same as when used with E lockers.
- Benny
