Blankman934
Hey Benny,
Do you have any info on the soft top storage bag (CWJ)?
Thanks
Thanks
The only thing I could find is an OE part number 68358392AA but this is unpriced and not available to order yet. It was only found under the 4 door model. I do not see a mopar accessory equivalent at this time so our best bet is to wait on the OE one once its available.Hey Benny,
Thanks
Hi Benny,
I need a new bracket that holds the steering stabilizer to the knuckle/track bar. It has three holes for bolts two of which attach the bracket, the other holds the stabilizer. Anyway you could track me that down?
If you need me to take a picture of the part I can!
There is only one wheel that I guess you can say does both which can be found here https://www.allmoparparts.com/sku/77072466ab.htmlMopar beadlock? Are there two beadlock wheels? A fake beadlock and a true beadlock? Also, can you buy replacement rings for the fake beadlock wheels?
Good question, I recall at one time they were discontinued but now that the wheels apply to the JL as well as the JK it looks like they will be made available again. They are currently unpriced though. The part # is 68362086AA , Please feel free to check back with me in time.But can you buy new fake rings?
Honestly I do not know and there is no mention within the owners manual about this, There are also no TSB's or tech tips about it.Is there a limit to the size on a thumb drive I can put in the USB Ports?
I have a 128G and when I put it it it says ERROR.
Thoughts?
Is this the configuration currently in your JL? If so send me your VIN as it will help filter out the correct wiringHi Benny, do you have the wiring diagram for the 2018 JL Unlimited Rubicon without the Alpine audio system and with the 7-inch screen? Need the wire colors and polarity for an aftermarket speaker/amp upgrade. I'm aware of all of the parts/components I need to convert the signals, I simply need the wire color and polarity for each of the speakers. Thanks much, and we truly appreciate all you are doing for this community!
