How Can We Help?
AllMoparParts.com
AllMoparParts.com
Peak Sponsor (Level 2)
Benny
NY
2018 JL
VIN 1C4HJXDN0MW602754
After more investigation, I've come to the same conclusion regarding the LEDs. Looks like I would need to replace the fender also. Closest match to what I have now would be a textured (non-Rubi) fender with LEDs. Does it exist?
Agreed you need the "2 piece" in a textured finish. Yes they exist here are the links
https://parts.allmoparparts.com/oem-parts/mopar-wheel-flare-molding-left-6ce71rxfag
https://parts.allmoparparts.com/oem-parts/mopar-wheel-flare-molding-right-6ce70rxfag
Please let me know if you have any other questions.
Thanks,
-Benny
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hi Benny. How would I get the hardware for the Mopar 82215428 mounting brackets. Once these brackets are installed the hardware can not be removed since the pressure sleeves are left in the bumper. Thanks...
Hi Chris,
The hardware is not available separately but rivnuts are a common part. While mopar uses and sells these in OE applications I do not have the kit thread dimensions nor do I have the dimensions for the ones mopar offers.
Best bet is to measure the bolt thread size and then find a generic set on amazon.
- Benny
Altitude2020
Canada
2020 Jeep Wrangler JLU Altitude
Hi Chris,
- Benny
Thank you Benny, I thought they where called something else. So the actual name of the nuts should help.
Nvrmor
Jon
Arkansas, USA
2020 JLU Rubi on order
Brandt power unit operator
Can you get the rubber seal that goes between the hood and the windshield tie down loops by themselves?
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Sorry Jon but I do not see these being sold separately.
Thanks,
-Benny
operator22
Bob
Tampa, Florida
2021 JLU Willys
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Benny, are these part numbers for the fenders that sit higher like the Rubicon? Do they include lights?
Hi Bob,
Bob, I stand corrected and need to clarify more here as I have dug deeper into these never ending flare combinations as it seems.
Here are my findings:
2 pc. Textured High fender with dual type halogen lamp housings
6CE71RXFAG
6CE70RXFAG
Jeep Wrangler JL How Can We Help? 1608147860562
2 pc. Textured Low fender with dual type halogen lamp housings
6XQ53RXFAB
6XQ52RXFAB
Jeep Wrangler JL How Can We Help? 1608147839289
2 pc. Textured High fender with LED DRL's
6CE73RXFAG
6CE72RXFAG
Jeep Wrangler JL How Can We Help? 1608148089687
With that being said the flares do come with the lamps. Another important note is that the Dual Halogen lamp type flare can accept the LED DRL but the low base single halogen lamp style (not pictured) cannot.
The combination of Low, Textured W/LED DRL from the factory does not see to exist, at least not yet. Therefore you will need to purchase the flares below + a set of DRL Lamps.
6XQ53RXFAB
6XQ52RXFAB
I will probably create a new sticky thread with all of the other flare combos for future reference. Please let me know if you have any other questions.
Thanks,
-Benny
operator22
Bob
Tampa, Florida
2021 JLU Willys
Hi Bob,
6CE71RXFAG
6CE70RXFAG
6XQ53RXFAB
6XQ52RXFAB
6CE73RXFAG
6CE72RXFAG
6XQ53RXFAB
6XQ52RXFAB
Thanks,
-Benny
Thanks for the research Benny. And yes, I discovered that the LED DRL's that I bought won't fit the low fenders since they are too wide. Will have to decide what to do next.
TP1
2021 JLU
@AllMoparParts.com hoping you can help. Placed an order on December 6th and it still shows in process and has yet to ship. Can you provide any insight? Getting a little frustrated at this point.
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Sure please PM me your order number and I will find out whats happening.
- Benny
americonium
Abe
NY
2018 JLUR Black
Engineering Technician
Hey Benny, hope all is well. I'm looking at 123220RR. I know it isn't for the JL, but I'm pretty sure I can adapt it to work. Do you think it would arrive before Christmas? Otherwise, I'll wait until spring. Thanks in advance.
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hi Abe,
This is special order and would not arrive before Christmas.
Thanks,
-Benny
Spank
@AllMoparParts.com Are you able to get supplemental parts that come with kits? I'm looking for the Hood Trim Kit box (K6862820) that comes with the Mopar Snorkel. I don't need the entire snorkel, the a-pillar mount, or any of the major hardware, but I would like to replace the trim piece that goes over the hood cutout. Mine is falling apart.
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hi,
I don't see it available separate but have sent a message over to mopar to see for certain. I will reply back once I hear from them.
Thanks,
- Benny
Spank
Hi,
Thanks,
- Benny
Awesome. Thank you!
