How Can We Help?
Hercules
Clearwater, FL
2012 Ram 2500 Longhorn, 2022 JLURD
Hi,
Please send me your VIN and I will lookup the flare part numbers and send links.
Thanks,
- Benny
I’ve since found out that the two parts that need mopar doesn’t sell separately- they come only with the full fender flare assembly. It’s the little brace thing at the bottom rear of the fender and fender flare.
Unless I’m missing something….not sure I can get what I need without buying 2 whole new flares. I might just try and fab a little brace
AllMoparParts.com
AllMoparParts.com
Peak Sponsor (Level 2)
Benny
NY
2018 JL
Benny - I would like to request a couple part numbers. I need the 4 bolts that attach the soft top to the roll cage on my 2023 Wrangler JLU. It appears to be two short bolts on the bottom and the two longer bolts on the top. To be clearer, the bolts hold the top frame to the big plastic pieces (Bow assembly???) that contain the "locking switches" that lock the soft top up or down. Right now I have 4 of the hard top bolts holding the soft top to the roll bar, but want to get the proper bolts for the job. They may be 68399007AA and 06512230AA? You rock...
Hi Mark,
Please take a look at this thread I created here along with the part images in the links. If you do not see them there let me know https://www.jlwranglerforums.com/forum/threads/factory-soft-top-hardware-list.114954/
Thanks,
- Benny
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Correct and that's what was mentioned in the original post. I had thought you were looking for new flares at this time.
- Benny
Avi8or
MO
‘23 JL 2 Door
Hello Benny,
I need the following parts for a '23 JL Sport S. I am installing a steel skid plate from a Gladiator and need the four mounting brackets and associated hardware. I also put Gladiator takeoff wheels without TPMS and need 5 sensors.
For the skid plate:
6511076AA - eight (8)
6104414AA - eight (8)
6512587AA - four (4)
68353837AB - one (1)
68353836AB - one (1)
68356520AB - one (1)
68356521AB - one (1)
TPMS Sensors (as far as I can tell)
68339096AB - five (5)
68494962AA - one (1) not sure this is right. need one rubber valve stem that can accept TPMS on the Gladiator steel spare.
daniel5678
2021 jlu
Hi Benny
I want to order an engine, the part number is Part#68565534AC
Is there an ETA if I order now?
thankyou
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hello Benny,
For the skid plate:
Hi,
Here are links to all of the items, Please adjust the qty's accordingly
https://parts.allmoparparts.com/oem-parts/mopar-mopar-rivnut-m10-6511076aa
https://parts.allmoparparts.com/oem-parts/mopar-hex-head-bolt-and-coned-washer-6104414aa
https://parts.allmoparparts.com/oem-parts/mopar-screw-6512587aa
https://parts.allmoparparts.com/oem-parts/mopar-skid-plate-bracket-left-68353837ab
https://parts.allmoparparts.com/oem-parts/mopar-skid-plate-bracket-right-68353836ab
https://parts.allmoparparts.com/oem-parts/mopar-skid-plate-bracket-right-68356520ab
https://parts.allmoparparts.com/oem-parts/mopar-skid-plate-bracket-left-68356521ab
Yout TPMS # is correct
https://parts.allmoparparts.com/oem-parts/mopar-tire-pressure-sensor-68339096ab
These include rubber valve stems with them. You can use them in steel or aluminum wheels
Jeep Wrangler JL How Can We Help? 1687835985600
I will PM you a code you can use. Please let me know if you have any other questions.
Thanks,
-Benny
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hi Benny
thankyou
Hi Daniel,
This is on a pretty bad backorder at the moment, I can only estimate it would take 45 days to get based on previous orders. This is just an estimate but if your timeline allows for this let me know and we can discuss pricing and logistics.
Thanks,
- Benny
JLrecon
Alex
Dominican Republic
JL Rubicon unlimited 2.0
Hi benny,
i’m looking at this part number68432441AC for my car.
Would like to confirm if this fit my car before ordering
2020 jeep wrangler rubicon unlimited
2.0 4 cylinder turbo e-torque
Vin 1C4HJXFN7LW304536
thank you
Alex joa
Jeep Wrangler JL How Can We Help? IMG_9803
Jeep Wrangler JL How Can We Help? IMG_9804
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hi benny,
thank you
Alex joa
Hi Alex,
Your part # is correct. This can be ordered here
https://parts.allmoparparts.com/oem-parts/mopar-alternator-kit-68432441ac
It will take us about 7 days to get. Please let me know if you have any other questions.
Thanks,
-Benny
Spank
Hey Benny,
I've got a cart on your site for a few items, but shipping is $320.
Bell housing plugs - 4593887AB
Rear tailgate actuator - 68282968AA
Rear tailgate plastic - 6BM40TX7AC
There a way to get these items shipped at a more reasonable cost?
Thanks!
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hey Benny,
Thanks!
Looks like there were some Dim errors. Please clear your cookies and re-add the items to your cart. I will also send you a code to use now.
Thanks!
- Benny
Hahmster
Larson
Buena Park, CA
2007 Toyota FJ Cruiser; 2022 JLU Rubicon XR
Hi Benny,
I have a 2022 JLU Rubicon Extreme Recon. My understanding is that the XR comes with bigger brakes over the standard Rubicon (Are they Gladiator brakes?). Can you please get me the parts numbers for the: (1) front and rear brake calipers; (2) front and rear brake pad replacement kits; (3) the parts numbers just for the front and rear brake pad hardware/spring retention clips.
Just like some Gladiator owners, I have had some serious rotational squealing noise and discovered it was coming from some stuck caliper slide pins. I greased them up and it solved the problem for a while but the noise has come back. I broke a couple of the brake pad springs clips in the process of removing and reinstalling the brake pads so that may have contributed to the remerging noise. Eventually though, I may consider talking to the dealership and having them possible replace the guilty calipers/pins under warranty or just purchasing a new set out-of-pocket.
Thanks!
New4xeguy
DC
Wrangler 4xe
Hey Benny.
You have any information about the Power Box that was supposed to be standard on all trims of 2024 Wrangler 4xes? Seems Jeep has backtracked on that, so might need to buy one. Unclear if/when they’ll be available to purchase anywhere.
