How Can We Help?
AllMoparParts.com
AllMoparParts.com
Peak Sponsor (Level 2)
Benny
NY
2018 JL
Benny:
I have a 2021 JL that I just bought second-hand OEM half-doors for. I converted my full-size driver's door to a proximity look through your kit. I want to convert the driver's half-door as well. They're not listed on your site, and I want to know if I can put the "kit" together by substituting the half-door harness? Unfortunately, I can't figure out that part number. The doors have power, heated mirrors, and power locks (Obviously).
Do you know the part number, and can I get it from you guys with the proper driver's door handle as a kit? I THINK that I want 68477709AC, but it shows as "Right" side, even though 68477717AC also shows as "Right"...
Hi,
This is the harness youll need
https://parts.allmoparparts.com/oem-parts/mopar-front-door-wiring-68477709ac
The rest of the parts are all the same, Here are the links for those parts
https://parts.allmoparparts.com/oem-parts/mopar-exterior-door-handle-right-68307269ae
https://parts.allmoparparts.com/oem...eft-or-right-front-w-passive-entry-68307272ae
I will send a code you can use as well.
- Benny
au176
WNY
2021 Islander, 2020 Newmar Ventana, 2014 HD Road King
Tired again
MarkyMark
San Francisco, CA
19 Rubicon JLU 2.0t w/ eTorque & Moto Guzzi Griso
Hi there, I have a 2019 Jeep Rubicon JLU 2.0L eTorque. I'm changing the front differential cover and thus fluid. Two questions:
1) Can I reuse my current gasket? (I've heard I can but want to verify.)
2) What fluid do I need, how much of it, and how much does it cost? Hoping you can ship fluid.
Thanks! Mark
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Thanks! Mark
Hi Mark,
I dont see any mention of not being able to reuse the gasket however the bolts are not to be reused. See attached
Bolt kit is on backorder for a few weeks
https://parts.allmoparparts.com/oem...r-bolt-kit-front-or-rear-set-of-12-68394154ab
I am sorry we do not ship fluid but you would need part # 68378949AA x2 (quart)
Please let me know if you have any other questions.
Thanks,
-Benny
MarkyMark
San Francisco, CA
Hi Mark,
Thanks,
-Benny
Benny, thanks for the info. You’re awesome. I have the bolts with my new diff cover. But was hoping to save $$$ on the gasket. Now just need to source the lube locally. Appreciate you.
Antonio
Antonio
NJ
2022 JLU Rubicon diesel
Hi good morning Benny @AllMoparParts.com
Could you please let me know if you have an item number for mopar coolant fluid for a MY22 3.0 diesel engine, thank you!!
npj01
Nicholas
New Hampshire
JL Moab
Hi Benny, I’m buying a set of half doors for a 2023 for my 2018. My 2018 has the blind spot and heated mirrors and the 2023 doors only have the heated. What do I just need new mirrors or do I need a wiring harness too?
Jst42ln
NJ
2022 High Tide
Hey Benny
Is there a replacement fabric for the JL soft top, mice ate holes in mine.
Thanks
au176
WNY
Tired again
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hi Antonio,
Sorry I have been out sick. We do not ship/sell fluids at this time. The part # for the gallon is 68163848AB.
Thanks,
-Benny
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hi,
According to my data all the half door harness's support blind spot detection so the stock ones you have should work. The mirrors are different, Here are links
https://parts.allmoparparts.com/oem-parts/mopar-outside-rear-view-mirror-left-68281893af
https://parts.allmoparparts.com/oem-parts/mopar-outside-rear-view-mirror-right-68281892ae
Thanks,
-Benny
