How Can We Help?
AllMoparParts.com
AllMoparParts.com
Peak Sponsor (Level 2)
Benny
NY
2018 JL
Shinwoo Jang
Shinwoo
Korea
2021 Wrangler Rubicon 4-Doors, 2.0 Liter
Louisville
Mountains
2021 Rubicon
Hey Benny,
I'm needing to order a Left Rear ( driver side ) fender flare for a 2021 2dr Rubicon. Would you mind to verify I have the correct part number. I'm thinking it's " 6CE79RXFAE ". It's the standard black non painted flare.
Thank you.
stumblinhorse
Hey Benny, hope you had a great weekend. Finally getting a little melting and took the Jeep up over a couple high mountain passes. Snow taller than the Jeep.
Now I need a mopar rear cargo liner for leather seats. They come with the “snaps” that you have to cut the carpet a little. Right? And they are available now correct?
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hey Benny,
Thank you.
Hi Dave,
Yes that is correct
Please let me know if you have any other questions.
Thanks,
-Benny
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hi,
My weekend did not consist of any snow so I cant complain! :) Glad things are starting to melt up there for you.
Yes the liners include the snaps and are in stock, The kit can be found here
https://www.allmoparparts.com/sku/82215185ac.html
Thanks,
-Benny
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
I'd like matching left and right rear tow hooks on my wrangler sport. Can I just buy a rubicon passenger side rear tow hook and install in on my sport? If yes, what is the part number?
Hi Jim,
I am not aware of any Wranglers that have a right side rear hook and I do not show any in our dealer data. Did you see this in a photo you can share?
- Benny
jstoddard
SF Bay Area, CA
2021 JLUR
Hi Benny - you helped me out when upgrading our JLUR radio from 7" to 8.4". Now I am trying to recycle that 7" UAG radio to our 2014 Grand Cherokee so that I can use Carplay in that car. I am looking for the correct bezel that will fit the 7" radio (the GC currently has the 8.4" model without carplay). The 2014 GC is a Limited with heated seats and parking sensors. The bezel that I've found online that I *think* works is part # 68333927AC. This is for a 2018 GC, but I believe it should be backwards compatible. 2018 is the first year that they put this 7" UAG model in the GC. Can you confirm if this is the correct bezel? If it came in colors, we currently have the bronze color in the car and that would be easiest to match. I know I will also need the new USB ports as well. Thanks for any help you can provide! Jeff
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hi Jeff,
Im not going to be able to have a solid 100% answer on this because this combination did not exist in 2014.
Here is a photo of the bezel part number you came up with, I can confirm it is for a 7"
Jeep Wrangler JL How Can We Help? 1680732776505
I believe it will fit the dash because the same structure part number is used all the way up to 2023 but I question the color of the finish. If you send me your VIN maybe there is a color code I can see and compare.
- Benny
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
As I have searched I think the JK rubicons had a passenger side hook.
Can you ask the designers why there is no passenger side hook option on the JL?
Sorry we don't have a line direct to Jeep engineering, That would be cool if we did. My guess would be they wanted ample clearance for different exhaust/tailpipe configurations. I think someone early on poked their head to see if there were any hook provisions and none were found.
- Benny
jstoddard
SF Bay Area, CA
2021 JLUR
Hi Benny - thanks so much!
The VIN on the 2014 GC is 1C4RJFBG7EC372796
Its probably not helpful, but I have attached a picture of the current bezel below. I do see that this bezel that you posted has one additional button on the bottom row (looks like it says "Sport") - I assume that would just be non-functional
I really appreciate the help!
Thanks,
Hi Jeff,
- Benny
Jeep Wrangler JL How Can We Help? IMG_2410
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
So the problem is your interior trim code XSA MOROCCAN SUN INTERIOR ACCENTS was not offered in 2018 so this combination does not exist.
I was thinking maybe you can separate the black from the color keyed portion but I dont think thats possible based on this photo
Jeep Wrangler JL How Can We Help? 1680737455433
You should be able to swap your switches and controls over which is one less thing to worry about.
- Benny
