How Can We Help?
AllMoparParts.com
AllMoparParts.com
Peak Sponsor (Level 2)
Benny
NY
2018 JL
Hi Benny @AllMoparParts.com and thanks again for helping out here. My question is: are the spring isolators and upper location collars the same on all trims of Jeeps? For example, between the 392 and a 2021 JLU Sahara? Will be installing some 392 take-offs springs and shocks and want to see what else I might need to replace. I also picked up a set of Mopar LCA from the lift kit. The Mopar lift kit seems to re-use the upper location collars (front and rear) and only seem to replace the front spring isolators. Please let me know if you need any specific info on my end. Thanks and Happy New Year!
Happy New Year David,
Here are my findings:
Front Upper Sahara 68253406AC
Front Upper 392 68253406AC
Front Upper 392 Recon 68253406AC
Front lower Sahara 68342245AC / 68342250AC
Front lower 392 68466077AA /68342250AC
Front lower 392 Recon 68342245AC/ 68342250AC
Rear upper Sahara 68273114AB
Rear Upper 392 68273114AB
Rear upper 392 Recon 68273114AB
Please let me know if you have any other questions.
Thanks,
-Benny
SoCal JLUS
Inland Empire (Greater Los Angeles)
2021 JLU Sahara 2.0T
Thanks,
-Benny
Thanks Benny! One more question, what would might be the part numbers for the front and rear bump stops for both the Sahara and the 392? Not sure if these would be a direct swap or if I might need extended bump stops instead.
SoCal JLUS
Thanks,
-Benny
So assuming my current parts are in good shape, it looks like I would only need to replace one of the lower front isolator pads? (The 6077AA instead of the current 2245AC?)
RenegadeT
Tony
North Carolina
77 CJ-7, 99 XJ, 2018 JLR
Hi Benny. Against my better judgement, I wheeled my 2018 JLR 3.6L V6 in the rocks without adding any additional skidplates. Earned a badge of honor, but crushed the exhaust y-pipe that crosses over right to left, in front of the auto. tranny pan.
Can you confirm p/n 68252391AM is what I need? Looks like its item 7 on the parts diagram, but the description is coming up as 'Exhaust Pipe and Converter'
Jeep Wrangler JL How Can We Help? 20221216_141907
Jeep Wrangler JL How Can We Help? Screenshot_20230102_194801
Do you have this y-pipe, and able to ship to 27357?
So, I've been looking at the aftermarket skids now. I think the answer is no...but does Mopar offer any additional skidplating in this area?
Thanks!
Saddle Tramp
Mitch
Hays NC
2021 Rubicon 3.0 Turbo Diesel
hey Benny
Happy new Year!
My wife has a 2022 Compass Limited and I was wondering if there is a retro fit, plug and play kit Home Link that I can install.
Thanks in advance
Mitch
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
On the front only the Recons have an exclusive part # 68548789AB
Rears are all the same
Thanks,
- Benny
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Thanks!
Hi Tony,
https://parts.allmoparparts.com/oem-parts/mopar-exhaust-pipe-and-converter-68252391am Is the correct part #. We would need about 7 days to get one. (No Cat is included, Not sure why its called this)
I am not seeing any factory or mopar skid plates for that area either.
I will send you a code to use on the pipe.
- Benny
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
hey Benny
Happy new Year!
Thanks in advance
Mitch
Happy New Year Mitch!
I would need your VIN to compare some harness part numbers and then we may need to validate if the circuits are present on the actual vehicle.
Send me a PM and I will dig into it.
- Benny
IQ_imbalance
Bob
Maryland
2022 JLU Rubicon 3.0d
Hi....looking for the mopar diesel fuel treatment. Would 05191800AB be the correct part number to order for a bottle?
Pobaw
Alex
2023 JLUR
Hi Benny, I was looking to purchase 82215120AD , anyway I could get a code to use on this? Thanks in advance!
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hi Bob,
I am sorry but we are not shipping any liquids or chemicals at the moment. Your part # looks correct
Jeep Wrangler JL How Can We Help? 1672858993236
- Benny
