Help with incorrectly threaded bolt
Rockstar08
2017 Jeep Wrangler Unlimited Sport
Or you can try helicoil if there is enough material thickness behind it.
wondering what kind of protection can the bull bar provide judging from those little hex screws. A bull bar at least should look like this.
Awesome picture I see you ran into another idiot Prius driver….lol…doesn’t look too bad though!
Rock Hopper
Nevada
2019 MOAB, 2021, GrCherokee, 2006 TJ, 2023 Corvette
Retired Firefighter
Don't you HATE it when a Prius gets stuck in your grill?
(High pressure hose usually gets them out)
acenines3
NJ
2018 Jeep Wrangler Sport JL
Tap and die set is one of the best tools you can buy!
Yakpimp
Yakpimp
Moderator
Moderator
K
PNW
I finally had some time to try this out. Ordered a tap and die set on Amazon with some oil and had fun figuring out how it worked. After a couple YT videos I was feeling pretty good about the process.
One week without a bolt in the hole had allowed a bit of rust to form in there. Brushed out what I could and took my time. It went super smoothly and I even fixed up the bolt.
I swapped the bolts around so that it wasn’t fixed bolt with fixed whole and got everything loosely screwed in. Tightened it up and no problems.
Thanks for the help/tips!
