Handbrake Ka-thunk ?
DogsRule
Northeast Ohio
2018 Mojito! JL
Need opinions. Pulling up on the handbrake give a strong feel of a single "ka-thunk" at mid throw. The dealer replaced the right rear brake plate assembly as he said there was a "cable lever" worn creating the issue. - No change.
Said I needed new rear pads/rotors. It needed done. So I did that. - No change.
Then they said the left rear brake plate will need replaced soon too.
The feel I get when pulling the handbrake up is that it's right under the console but inspection inside there revealed no issues. The area to look at seems right under the floorpan but over the tranny tail / transfer. - totally can't see without mirrors, cameras.
Any ideas to look before my backside freezes to my -18F garage floor?
Thanks.
areuriding
Ken
Manassas Park Va.
2021 Wrangler Rubicon XR/2026 Rubicon X on order
Semi Retired
Shot in the dark, did you look at the teeth the handbrake lever catches on?
basiblaster
canada
2023 jeep willys sport
The handbrake assembly is inside the jeep, under the center console, it’s 4 bolts to remove
I had to lift mine because my handbrake froze and disconnected when I tried to release it
Sandevino
North Texas
2025 Wrangler Rubicon, 2002 Wrangler X
Avoid the dealership parts canon…
Does the parking brake work?
