Halogen taillights to replace LED.
Terpsmandan
Penn Yan
22 JLUR with LED taillights and blind spot monitors. Can I swap in a set of halogen taillights w/o the blind spot monitors? LED’s are supposed to last longer…..but definitely not cheap, even used. Or is there an aftermarket alternative that some of you like.
Jeffy56
Payson, AZ
2018 Wrangler Unlimited Sport
You want to down-tech and devolve to Halogens from factory LEDs? It's possible by installing factory halogen tailight assemblies. You'll likely get warnings regards the blind side monitors, possibly the lights. But why?
Terpsmandan
Terpsmandan
Penn Yan
Have you seen the price of factory LED’s. I have the tail light portion not working on mine on the drivers side. Brake and turn work fine. 83k.
Heimkehr
Pennsylvania
2021 JLU 2.0T
Unlike the halogen headlights, the taillights aren't bad at all. They also have the advantage of looking much more correct on a Jeep than do the bulbous LED housings.
To be fair, the halogen tails could do with a brighter Reverse bulb. That's easily remedied.
Jeffy56
Payson, AZ
Check connections first, then consider aftermarket LEDs. The impression I get is that the blind side detectors transfer over to the new light assembly.
Terpsmandan
Terpsmandan
Penn Yan
That would be nice. Thanks.
Terpsmandan
Terpsmandan
Penn Yan
I found a set from OLM for just over $200 that work with factory LED’s. They have the blind spot monitor plug built in and the seal was easy. Thanks for the info.
Jeffy56
Payson, AZ
Sure. You should put a link in so that others can check it out.
Terpsmandan
Terpsmandan
Penn Yan
