Genesis Battery for 3.0L
GSLSE21B
Fair oaks
2021 jLURD
Any chance yall will develop something with lithium batterys in mind. I just finished building this, it's still being tested and cleaned up. But 100 ah of batterys is pretty nice.
I have 280ah , runs my CFX3 45 for a month without charging
Logalinipoo
Logan
Odessa, TX, USA
2021 jlur diesel, 2011 grand cherokee overland sum
I bought 315, but I'm planing on running 210.
Can you detail what battery packs those are? Thanks!
They are 105ah lithium cells. I ordered them from aliexpress. The key was the size. I'll try to find them for you.
Logalinipoo
Logan
Odessa, TX, USA
The pair of Odyssey group 25's are 110 Ahr.
They might be 110, but only 50 percent usable if you want any decent life out of them. And one is for the starter. So you only have 25 usable ah. On a hot day that won't run a fridge more than a day or so. Oh and I have a diesel so the dual battery kit isn't an option, the last I looked.
Then you couple in the charge time. With a smart alternator only putting out 12.6 volts the odesy batterys will never really charge. If they do it'll take all day of driving to charge. Even if you couple in a dcdc charger led acid take so long to really get charged it's crazy.
With lithium and a 25amp dc to dc charger. It only takes one hour of drive time to recharge the batterys, 3 hours if you've really depleted them. They also have 80 percent depth of discharge for a much longer service life. And overall less weight on the vehicle.
Lithium is pretty much a win for everything except cost. And that 105 ah pack cost me about 250 bucks. Less than 300 with wiring fuseblock and all.
Compression-Ignition
Roy
Montana
'22 JLUR 3.0 Diesel, '20 6.7L F350, '94 12 valve
Lithium won't work for cold weather folks correct? So that would eliminate what 25%-50% of his customer base.
Logalinipoo
Logan
Odessa, TX, USA
Yes that can be a concern.
Lithium can't be charged below freezing. The controllers for them prevent it, so you aren't at risk of damaging the battery.
They have battery heaters for that. Or you can simply pull a load on them to warm them up before charging.
TX_Ovrlnd
CStat, TX
'22 Zilver JLURD
freethinker
Genesis Offroad
Olive Branch, MS
'16 JK Rubicon, '18 JL Rubicon, '21 JT Rubicon
Good things come to those who wait!
Everything takes longer than we want right now, but I promise the diesel kit is in development!
LooselyHeldPlans
Brandon
SW Colorado
2020 3.6 JLUR
Several
This!!!!
I don’t know why anyone would want a dual battery lead acid anchor above their front axle.
@Genesis Offroad what we really need is a well thought out and documented ESS delete to one smallish lead acid under the hood and a lifepo4 in the cab. I’ve got 4kwh (will add another 4 later) on a boat to me now and would certainly pay to outsource some of the design for this system.
Mr. Curti
Justin Curti
Tulare, California
2020 JL EcoDiesel
Dairy Farmer
Good to hear/know. I’m sure there is a bunch of us eagerly waiting. I know I am.
IQ_imbalance
Bob
Maryland
2022 JLU Rubicon 3.0d
Silly question...but where does the second battery go? Is there room for two group 25's in the diesel engine bay?
