Folding Jerry Can Mount
Status
Not open for further replies.
Flagstaff, Arizona
www.markprecisionautomotive.com
Machinist / mad scientist
Our Folding Jerry Can Mount provides a way to mount a five gallon Jerry can to the tailgate of your JL Wrangler. Extend your range without sacrificing needed space.
Features include:
-Lockable top handle (lock included) which prevents theft of your Jerry can
-Folding base plate that allows full range of motion of your tailgate should you want/need to remove your Jerry can
-A rubber bump stop that prevents your Jerry can from contacting the passenger tail light when opening the tailgate
-All-weather retention strap which provides additional support to the Jerry can. This strap is removable in order to prevent it from whipping your vehicle when the mount is stowed without a Jerry can
-Billet 6061 aluminum construction. This alloy is commonly used in both aerospace and military constructs
-Type 3 hardcoat anodize ensures that the finish won't chip, flake, or fade from UV exposure unlike many paints or other finishing processes
-Doesn't occlude rear back-up camera significantly (see picture below)
-No drilling or permanent modification is required to install this product. It simply replaces two of the factory torx bolts on the tailgate hinge with two longer zinc plated bolts
-Made in Arizona using precision CNC machining centers
-Small batch production. As a small business our costs are much higher than that of a large corporation. To compensate for this, we make quality and attention to detail our top priorities in all of our products. Nothing leaves our shop without a thorough inspection and dimensional measurements taken at every step along the way
-Limited lifetime warranty
-Free shipping to lower 48
Q
: Why should I choose this products instead of, say, five separately mounted one gallon plastic cans?
A
: Our intention is to consolidate all of your liquid storing needs in one out of the way area without having to take up needed space on the exterior. Adding five separately mounted cans takes up space and, with a spare tire mount for example, can occlude visibility through your rear window. The cost of various separate cans and their associated mounting hardware quickly add up in both the time it takes to install them and the expense required to do so. Additionally, when it comes time to use or refill your cans it is much faster and easier to refill/dispense from a single five gallon vessel than it is to deal with five separate one gallon vessels.
I can answer any questions regarding the Folding Jerry Can Mount on this post, or, feel free to contact us through our website HERE
Remember to enter the code JLTEN at checkout to receive a 10% discount!
Jeep Wrangler JL Folding Jerry Can Mount jcan1
Jeep Wrangler JL Folding Jerry Can Mount jcan3
Jeep Wrangler JL Folding Jerry Can Mount jcan4
Jeep Wrangler JL Folding Jerry Can Mount jcan5
dpike
New Jersey
'20 JLUR 3.6
Looks nice, great work. What's the ETA on the NATO can holder and will this mount with the Mopar tailgate reinforcement.
Mark Precision Automotive
Flagstaff, Arizona
Hello,
Thanks for the compliment on the mount. ETA on the NATO can mount is two months. As far as the tailgate reinforcement we are already working on an offset adapter that will accommodate bigger tires when using that part.
Regards,
Status
