floor carpet removal + interior rhino spray lining
cgpratt
tim
buffalo ny
07 jk sahara, 18 sport s jl
I guess i'll be the first. After 8 miles on the jeep and 3 rock chips!!!! I decided to rhino line the inside and jams. The carpet was designed to come out. It has snap out pieces. All carpet came out in about 10 minutes. My game plan is after it is rhino lined put the carpet back in for the time being. You can raise the snaps (they screw in) to off set the rhino thinness. Here is what the inside looks like with the carpet removed. I think the sound deadening looks better than my JK. If you zoom in you can see the snaps.
popped in to see how it was going. they are putting it back together. here are a couple of pictures
Couple more pics. They are still putting it together. They had a full day of prep and taping!!!
cgpratt
tim
buffalo ny
rhino line was going to get done at some point. Im not a craze person, i dont care what anyone else does. the chips just moved it up. I drive without a top all summer so rhino helps with the weather. I do the inside of the jeep and the door openings. The door openings are where the rocks hit and caused the chips.
KDB
WI
2018 2 Door JLR
I’ll be honest, I don’t get the rhino line craze.
Where did you get rock chips and how did that factor into rhino lining the Jeep?
I removed my carpet and line-x the entire inside of my JK years ago. Best mod I ever did. Easy to clean, just pull the drain plugs and hose it out. Also helps with chips, rust protection and sound deadening. Once my 2 door JLR is built this will be one of my first mods again.
cgpratt
tim
buffalo ny
agree! i was so pissed getting the chips pulling off the dealer lot. if that didnt happen, i would of used 3m protector for the jams for the first couple of years.
KDB
WI
2018 2 Door JLR
Agree with your assessment on the factory sound deadening material as well. The JL looks WAY better, they must have anticipated people will eventually rip out the carpet so planned ahead :rock:
Zeus
Republic of Texas
07 FJ (+about $30k)/14 4runner on 6112s n Icons (looking at JLURs)
Bravo! Will probably do the same. I've always been a function over form person myself. Don't let any with weak constitutions dissuade you!
Ponyracer
Phill
Beale Afb
2018 JLU, 1986 YJ Brute (project!)
I’ve got raptor liner sitting in the garage. Will be doing the same in the next few weeks. Question, did you pull you console yet? Any tips?
cgpratt
tim
buffalo ny
Did not pull anything else. The place that's doing it will. They did my jk and did such a great job, I wasn't going to mess with doing it myself on the new jl. I did the inside and the outside myself on my yj. In my opinion they made the jl to polished. Needs more of a jeep look on the inside. I do like how the windowfolds though.
Matthew/E36
Classified
StL
Two Thousand and Eighteen Jeep Wrangler Unlimited
Interested in what you did here, but know little about rhino lining...thought it was just for sound deadening underneath the carpets. Is the rhino line the pre-cut nearly black thin pad in the pictures? I guess it comes pre-cut to those patterns, but it seems to leave a lot of surface area uncovered.
Maybe I'm missing something.
Thanks for the info!
R3D J33P
JC
Ohio
2018 JLUR - Firecracker Red
Make sure to post after pics. I am really curious to see all the places you will have the Rhino spray on. I think this sounds like a great idea.
Majestic
NC
2013 JKUR, 2019 JLUR
Its the heavily textured truck bed liner that you spray on. People then typically leave out their carpets to make the Jeep feel "less refined".
Wannamojito
Wannamojito
Ontario
Yj
I had my JY sprayed with bed liner and loved it, it makes it very wash and wear. Post pix and price if possible.
  • Like
Reactions: KDB
KDB
WI
2018 2 Door JLR
When I had my JK done I took out the rear and front passenger seatbut left the driver seat (had to drive it there ;)). The shop I had it sprayed at removed the console and drivers seat. I went over the rails in the tube, did roll bars and door sills as well. Back then (2010?) it cost me ~$400-500 and I was living in AZ then. Wondering what it will cost to have similar done here in WI........
