Finally did a chalk test on 37s
Jerrybizzle
Jerry
Idaho
2019 JLUR
Tech
9 inch wide wheel for me on 37 12.5 17 mastercraft mxt and I’m at 28 cold. Not sure if it’s full contact but seems to be their happy place.
Rdmitch
Ross
Elyria, Ohio
2020 JLUR, ford transit 250, 2017 Wrangler Smoky Mountain Edition
Mechanical designer /contractor and musician
Doesn’t the low tire pressure light drive you crazy ?
Thinman
Rich
CA
2020 JLUR, 2019 Rebel 12 and...... a 2012 Prius
I have 3 kids and can ignore anything :facepalm:
Still was getting complete coverage and ended up dropping down to 26 cold
Rdmitch
Ross
Elyria, Ohio
Jerrybizzle
Jerry
Idaho
2019 JLUR
Tech
Sounds like your answer just cost me a tazer
If you have a rubicon and use it off road the sway kill alone is worth the cost to me. Makes it where you can go over 18mph with the sway bar disconnected. With the stock setting as soon as you hit 18 it tries to reconnect and is very annoying. I don’t bomb at 50 with it disconnected but do hit 25 or so occasionally and it makes a world of difference. There are many other features I just don’t use them all. Here’s a comparison chart between lite and full.
Jeep Wrangler JL Finally did a chalk test on 37s 555F4A07-2AA0-4716-8619-2119CF14322A
TCogs1
Thomas
Somis
cj6
I run 37" Maxxis Creepy crawlers (trail only for the most part).. I started at 37.. noticed the crown and lack of full contact patch.. Called Maxxis engineer, he said for the JL weight and 10 ply x 1" thick wall, he suggested 20-23 depending on how aggressive I was on the street and 5-10 offroad..
I settled on 25 highway, 10 PSI offroad..
Hope that helps..
Jeep Wrangler JL Finally did a chalk test on 37s MVIMG_20191030_134200
