Fill the wheel well
Blckdog
Connecticut
2023 Willys JLU
Had planned on installing 285-70-17 KO3’s after the ARB bumper was put on.
For better clearance from the bumper to the fender flare, I put on Rubicon high rise fenders (thanks to Benny).
Have the standard Firestone MT 255-75-17’s on the Jeep still and now thinking I might need to go to a 34-35 instead of 33’s. Wheel wells now look like I missed leg day.
I want to keep the Willys Moab wheels. So backspacing may be an issue. Usage is 80-85% on road as a daily driver, but will see some beach and light trail usage.
Top and doors off in summer. Rubicon springs going on too. Gears are 3.45 but with the 8 peed AT and my usage, I don’t see a n issue for now.
I like the BFG brand, and thought 285-75-17 might be a good alternative, but they are only available in load range E.
In New England I need a good all weather tire.
Here is a view on the wheel well that needs to be filled out right. .
Help me fill it out right.
Jeep Wrangler JL Fill the wheel well IMG_0569
Jeep Wrangler JL Fill the wheel well IMG_0568
Jeep Wrangler JL Fill the wheel well IMG_0567
Jeep Wrangler JL Fill the wheel well IMG_0566
Speed331
Sean
Las Vegas, NV
2008 Jetta, 2018 Discovery Sport, 2020 Wrangler Sport S (on order)
Mickey Thompson Baja Boss a/t
285/70 r17
Great in the dirt, great on the highway and good grip in the rain.
2020 2 door with a 2.5" lift
Jeep Wrangler JL Fill the wheel well 20230413_105805
Jeep Wrangler JL Fill the wheel well 20230130_115427
Jeep Wrangler JL Fill the wheel well 20230130_115419
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Completely up to you, but I wouldn't concentrate on a standard view of fender gap, you want plenty of room for the axles to move around.
Some gives and takes with your options. Although you'll hear the Es ride rougher, in general adjusting to the correct tire pressure will get you closer to the same ride (you'll probably want to run the 75s a few psi lower than the 70s regardless). The bigger impacts are, of course, gearing and the 75 Es are going to be 10 lbs heavier a corner than the 70s. The weight will come with durability, though.
Your about 1.5" narrower at the axles with the Willys than a stock Rubi, but I think with the highlines you'll be okay. Worse case you can pad the steer stops a little.
I say if you want the taller tires, get them.
6th Floor Mule
Keith
Woodstock, GA
2018 JLU Sahara 6MT
Load range C 285/75 Ridge Grapplers helped “fill the gap” on my Sahara. I added Rubi fenders as well, but I have the TF 1.5” leveling kit.
Jeep Wrangler JL Fill the wheel well IMG_4331
Blckdog
Blckdog
Connecticut
2023 Willys JLU
Nice wheels Mule.
