Fender Flare Clips
DanFelix
Riverside, CA
2018 Wrangler JL Sport S, 3.6l
The supply for JL fender flare clips (OMIX FENDER FLARE CLIP W-TYPE 9.90 JL/JT 11609.41 ) is delayed and the earliest date I can find is April from Quadratec. Researching the same clip for the JK model shows that they "almost" look alike. Has anyone ever used both and will the JK version "sufficiently" work on a JL as to warrant their use?
Thanks.
CarbonSteel
The JK clips have to be modified to work on a JL. The middle has to be trimmed a bit. With that said the plastic the JK clips are made of are less brittle than the JK ones.
If you can't find JL clips, you could always pick up the JK ones from Amazon and compare/trim as necessary.
DanFelix
DanFelix
Riverside, CA
Thanks, everyone, for the great advice and leads. I will try the JK and report back with photos. Dan
