Extra 4-wire tow harness - thoughts?
mishkajb
Jerame
Frankfort, KY
2021 Wrangler Sport S JL
I bought a used 21 JL Wrangler. It has the factory tow options, with the 7/4 pin outlet. However, the previous owner installed a second 4-pin (and attached it right above the driver-side tow hook). It makes me wonder what he would have needed a second one for? Any thoughts, or something you have done with an additional power source?
A few thoughts that came to mind - the OEM 4-pin is bad. No, I haven't tested it (my trailer is on loan).
And it's not enough to power another device on a trailer, such as a remote winch or trailer-mounted battery for a winch.
Maybe he towed a float for a parade and used it to power LED lights??
Vinman
Vince
Calgary, Alberta
2021 JLU Rubicon
Jeep was probably flat towed behind a motorhome and the additional plug was to power temporary tail lights. Check the front of the Jeep for a similar plug that would connect to the tow vehicle.
I know thats exactly how I plan to wire tail lights when I set mine up to flat tow next year.
mishkajb
mishkajb
Jerame
Frankfort, KY
That's possible, it's tied directly into the OEM harness. Nothing on the front of the Jeep for wiring, but it did have what appeared to be a emergency braking cable if it was towed.
Heimkehr
Pennsylvania
2021 JLU 2.0T
Here's an inexpensive tester that would allow you to perform troubleshooting sans a trailer hookup.
mishkajb
mishkajb
Jerame
Frankfort, KY
I've never seen one of those before, that's pretty cool!
au176
WNY
2021 Islander, 2020 Newmar Ventana, 2014 HD Road King
Tired again
I'll be setting mine up as a toad next year as well, and am researching various options. Are you just running a REALLY long harness from the rear of the jeep all the way to the front to hook directly into the motorhome outlet, then connecting portable AUX lights on the rear?
au176
WNY
Tired again
And if you're really feeling froggy, spend an add'l. $2.50 for an inline version.
I have this, and plugged it in to a harness extension so I could place it where I could see it from the driver's seat when testing.
Vinman
Vince
Calgary, Alberta
2021 JLU Rubicon
Yes, using a kit like this one https://www.amazon.ca/CZC-AUTO-Magn...24f&gad_source=1#immersive-view_1732286833291
Will permanently run the wires through the interior of the Jeep then make a couple of disconnects at the rear bumper to connect the lights when towing. With the complexity of the Jeeps electrical system I have no desire to tap into it to use the stock tail lights when towing.
No need to even have to ignition on this way.
au176
WNY
Tired again
au176
WNY
Tired again
Interesting. We plan on having two bicycles on a rack on the back of the Jeep, and mounting something like this to the rack will actually make the lights MORE visible than stock...
Pretty simple- running the jeep like a trailer. Thanks!
houstonstroker
2021 Wrangler JLU
I bought this when I was setting up my JL to tow behind my motorhome.
Blue Ox BX88368 EZ Light Wiring Kit for Jeep Wrangler JL & Gladiator
From Amazon. I have used this for 3 years no problems.
au176
WNY
Tired again
I've looked at a similar product from Jeep. Do these go in the tailight housings?
