Engine cutting out on hill climb
Gunsmith
Jon
Hesperia, CA
2020 Sting-Gray JLUR Recon, 2000 BMW R1000RT
Mostly retired gunsmith
I may have missed this in a previous discussion but here goes anyway. I was trying to climb a big sand hill in 4 low and my engine started cutting out like it was missing. It also lost most of its power. Other than that, this Jeep has been flawless and is driven and enjoyed every day. I've never experienced this in any of my older Jeeps. The last one was a 2003 Rubicon.
dchemphill1
Nebraska
2020 Wrangler Rubicon Recon
School Administrator
Where you in manual mode? I found on some steep hills with loose material I like to control what gear is being used. In automatic it will tend to try and keep RPMs lower...not what you want on hill climb in sand.
Others may have better info than this.
Gunsmith
Gunsmith
Jon
Hesperia, CA
I was in manual mode, 2nd or 3rd gear.
johnnyj
Washington
Jeepless but still a fan.
I'm thinking you need to disable traction control/ESC functions. Before you do the sand, park the Jeep and poke the traction control button. Next, push it and hold it 5 seconds until the ESC disables. If you have these still on, even in manual mode/4wd, it will cut power to prevent wheel spin. You do not want that in sand or snow. Give it a go. =)
LongTimeListener
Arizona
JKURHR
I would make the same guess. I think the "GOAT" modes on the Bronco are gimmicky, but I wouldn't mind a dedicated "Sand" mode on the Jeep, for exactly this reason.
Gunsmith
Gunsmith
Jon
Hesperia, CA
OK, I'll disable the ESC next time. Thanks!!!
mgenbox
So. Indiana
21 Wrangler jl 2 dr sport
Dang. I wish I woulda seen this before I hit the dunes. I thought maybe the turbo was shutting down on high temp cuz I would climb the first big hill but a subsequent big hill it screwed me almost at the top a couple times
