DRL assistance
MyDaughters20JL
WA
20 JL Sport S
I believe I know what the problem is, but I just wanted to get a consensus from everybody else.
you installed a pair of keyway master LED headlights in my daughters non-LED equipped sport S. I got everything wired up as per directions including the top wire for the daytime running lights and they are not working. IA bought her the license for an OBDJ scan and I’m wondering if I just need to go in there and enable both LED lights and daytime running lights or is there something else that I’m not doing correctly?
Gregj
Greg
West Texas
You will also need to set the DRL location. Are you talking about the halos?
Gregj
MyDaughters20JL
MyDaughters20JL
WA
20 JL Sport S
thanks for the reply: as it turns out, I'm just a typical bone-headed truck driver :giggle:
when I opened the pack of fuse taps, I pulled one out. put the stock heated seat fuse in the lower position & one of the 20A fuses from the package in the upper position. got my wire crimper, grabbed the fuse tap & hooked everything up..no go on the drl/halos. figuring I had to configure them with the obd jscan, I began putting things away & picked up a fuse tap to put back in the package...one with 2 fuses in the added positions..looked & I'd installed the one without any fuses...swapped the fuses into the one installed in the jeep & viola! everything works as it should with no errors or codes & all lights working
Gregj
Greg
West Texas
All ways good when it is something simple.
Gregj
