DPF passive regen question
rickinAZ
rickinAZ
Rick
Phoenix
2026 MOAB 392
Thanks I’m gonna order some and try it out, the Scangauge comes with Velcro adhesives to use but I don’t know with the Sun heat from windshield etc how they would do after a year or so, trying taking them off after idk ?‍♂ I worry too much about later on issues lol ?
Just check your local craft store (Michaels or Joanns)
Capricorn
Las Vegas, NV
2024 JL Willys XR V6
Network Architect & Engineer
I got them on Amazon. Search for sticky dots.
mcjeff
Pittsburgh
2020 JLUR
Compression-Ignition
Roy
Montana
'22 JLUR 3.0 Diesel, '20 6.7L F350, '94 12 valve
Antonio
Antonio
NJ
2022 JLU Rubicon diesel
It’s the one directly from the ScaGauge site, from the manufacturer.
https://www.scangauge.com/shop/deluxe-window-mount/
Its worked great — hope that helps.
Thank you!
I ordered the dot sticky to try for now but if that fails this will be my next option ?
*** Also on another note any suggestions on what to monitor, besides the basics???
As of now I got the on/off regen, turbo temp, soot level and exhaust temp going in. I did code a few more option but only really watching these 4 is this appropriate set up or should I be watching other # thanks
Capricorn
Las Vegas, NV
Thank you!
My favorites are:
RGN
STM
TRB
DPF
I also toggle to TNR every few days. BST is interesting too but I believe the display for that caps of at 24.
Deleted member 59498
Guest
Is there some benefit or knowledge with knowing when it is regen?
Roy
Montana
If you drive short distances and happen to end up having multiple incomplete regeneration cycles it could cause issues. Other than that possibility, there is no reason IMO to worry about what the system is doing.
Guest
Ok thanks, just making sure. All the little tools add up to lots of $! :)
Not to mention wires and wire ties all over!
I do lots of short trips but also 30 to 40 mile trip couple times a week.
mcjeff
Pittsburgh
2020 JLUR
Go figure, I have the same one and it's terrible. Maybe you got stronger magnets....if that's a thing?
This thing has been great. It took me a minute to get it stuck right, but it hasn’t so much as wiggled since then. Sorry yours is a jerk!
mcjeff
Pittsburgh
2020 JLUR
My favorites are:
RGN
STM
TRB
DPF
Yup, exactly these and I also have TNR set and I check every now and then.
mcjeff
Pittsburgh
2020 JLUR
My trips are mixed. Usually either 400+ miles or a mile at a time. If I’m getting close to 80, I’ll just time it so I have enough time to let it finish before I get where I’m going.
It doesn’t worry me, I just like knowing what’s going on.
CJ SCION
Tim
Michigan
2024 JLU Willys
Tired Again
I use an iDash by Banks. It can clear codes (haven't used this feature yet), but I find it super helpful for monitoring temps and when a regen will happen and is happening. I am monitoring 8 items on a small 2in gauge up in the corner of my windshield. Easy to see and never in my way. I did a write up on the gauge pod install.
Items monitoring from top left to top right and down. Trans Temp, Oil Temp, Engine Load %, Coolant Temp, Batt V, DEF Tank Level, Regen Status, DPF Soot Level
Hey @brewski and all. Digging the iDash here also. The "pages" feature is a huge bonus and easy to access once they are set up, 5 pages with 8 parameters each is almost too much. Check this link for available options --> PIDs and BIDs link. I found the list useful when planning the layout of each page before programming the iDash.
Jeep Wrangler JL DPF passive regen question Pages
Booger sugar
Juan
Arizona
2022 JLUD
I use a ram phone mount and arm with 67d clamp and holds up well on the hardball ( reg roads ) havent been offroading yet so I don’t know
Jeep Wrangler JL DPF passive regen question 4982D75D-4D23-40CF-BC83-5A468AE15C67
