Door wiring harness pin layout
Recoil
Virginia
2021 80th Anniversary JLU
Does anyone have the pin layout for the connectors on the door's wiring harness? My passenger side defrost isn't working and I'm trying to troubleshoot it.
Infotainment
Summit Sponsor (Level 3)
Infotainment
Oviedo, Florida
infotainment.com
Various
Infotainment.com
This connector?
Jeep Wrangler JL Door wiring harness pin layout defrost
XY650A
Connector Details
  • Harness Family:
    Door_Pass
  • Color:
    BLACK
  • Gender:
    FEMALE
  • Part Number:
    7298-4329-30
  • Part Description:
  • Connector No:
    X650A
  • Option:
    HALF DOORS
  • Repair Kit Part Number:
    Mopar Connector Repair Kits
  • Cavity Count:
    30
Connector Views
Mating Side:
Jeep Wrangler JL Door wiring harness pin layout ode=&X-Auth-Token=ab8964869f134eceb291e7b46cfd2acf
Wire Insertion Side:
Isometric View:
Location Views
StandardView
PinCircuitWire ColorGauge/SizeFunctionOption
1N0NA0NO CONNECT
2C110DB/BU0.75MIRROR HEATER DRIVER
3E12OG/GY0.50PANEL LAMPS DRIVER
4N0NA0NO CONNECT
5G160VT/GN0.50RIGHT DOOR LOCK SWITCH STATUS
6N0NA0NO CONNECT
7L160WH/BG0.75RIGHT FRONT TURN SIGNAL CONTROL
8M5WH/GN0.50AMBIENT LIGHTING CONTROL
9N0NA0NO CONNECT
10N0NA0NO CONNECT
11P72BG/GY0.75PASSENGER MIRROR VERTICAL DRIVER
12Z910BK0.50GROUND
13N0NA0NO CONNECT
14P76BG/BU0.75MIRROR COMMON DRIVER
15P401GN/VT0.75RIGHT FRONT PASSIVE ENTRY HANDLE SWITCH RETURN
16P400GN/OG0.75RIGHT FRONT PASSIVE ENTRY HANDLE SWITCH SENSE
17P372BG/OG0.50DOOR LOCK SW RTN PASS
18G74VT/WH0.50PASSENGER DOOR AJAR SWITCH SENSE
19N0NA0NO CONNECT
20N0NA0NO CONNECT
21P712GN/WH0.75RIGHT BLIND SPOT INDICATOR DRIVER
22N0NA0NO CONNECT
23N0NA0NO CONNECT
24P74BG/OG0.75PASSENGER MIRROR HORIZONTAL DRIVER
25N0NA0NO CONNECT
26P777GN/DG0.75DOOR LOCK CONTROL
27P292VT/GN0.75DOOR UNLOCK CONTROL
28N0NA0NO CONNECT
29N0NA0NO CONNECT
30N0NA0NO CONNECT
