DaltonGang
- Sep 29, 2018
- Doesn't Play Well With Others
- 2018 Wrangler JLU Sport S, Rubicon Suspension, Rims. Firecracker Red
I agree, try the easiest, and less expensive fix first. I am currently running the Mobil 1 0w-40 Euro spec. Wonderful oil, and my engine is quiet as can be, at 41,000 miles.I and several others run 40 grade motor oil as it helps with residual boundary layer and lubrication. I’m on AZ and run Castrol Edge Euro 5w-40. If I lived in a colder environment I’d run 0w-40 such as Castrol or Mobil 1 FS Euro.
Make sure to drive spirited above 3000 rpm as that will push the variable displacement oil pump onto high pressure and help lubrication. Just search my posts for more info.
When, and if you change the oil, see what is inside the oil filter.
