Does Anyone Make Wider Rubicon Style Wheels?
george33
George
Allentown, PA
2019 RAM, 22 Rubicon & others some stay some don't
I like the wheels on my JLR, just wish the 17x7.5 oem rims were a little wider.
Does anyone make a wider Rubicon style wheel?
Maybe 1/2" or 1" wider than oem.
As a second question . . . .
What is the widest "recommended" tire that can be mounted on the 17x7.5 oem Rubicon wheel?
The operative word here is "recommended." ;)
Thank you.
Bryce
Bryce
Acworth, GA
2019 JLUR
Yep. Check out the Quadratec Morphic wheel with Machined Face. 17x8.5 +10mm
Jeep Wrangler JL Does Anyone Make Wider Rubicon Style Wheels? Screenshot_20220720-130448_Chrom
Old Dogger
Cave Creek Arizona
For a 7.5” Rim width, a 33… Some will mount 35’s, but most reputable tire shops, won’t mount them.
george33
george33
George
Allentown, PA
So, with let's say a 295 or 305 tire, will this 17x8.5 +10mm offset wheel have any poke?
CarbonSteel
A stock wheel is +44mm offset so a +10mm will be 34mm closer to the outside of the fender. I am running Icon Alphas with 0mm offset in 17 x 8.5 and 37x12.5x17 tires. Here is a side shot (take into account the XR fender extensions). The +10mm wheels will be 10mm less poke than this:
Jeep Wrangler JL Does Anyone Make Wider Rubicon Style Wheels? 20220312_180103
Odyssey USA
Daniel
www.youtube.com
2021 JLU Rubicon
Stock Rubi wheels with spacers and 37s. Poor man’s bead locks. Accidentally ran them at 5 psi. YMMV!
That’s why I like to run my tires wide for the wheel they’re mounted on. My 295 Mickey Thompson BB AT is the widest they recommend for a 7.5” wheel. Any shop should have no problem following the tire manufacturers recommendation.
Chile1
Missouri
2018 JLUR & 2016 BMW X5M
Biotech Sales Management
how much wider do you need - i have the Mopar bead locks on 37':
Jeep Wrangler JL Does Anyone Make Wider Rubicon Style Wheels? 1658340310601
Jeep Wrangler JL Does Anyone Make Wider Rubicon Style Wheels? 1658340449933
RugbyRef
Tim
South
2021 Jeep JL 392
The first thing I did to my '21 392 was to put 37x12.5's on all OEM wheels (17x7.5). Never had a problem with them on the trail when aired down. I have them on aftermarket wheels now, however.
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
It’s hard to tell +10 from zero. But +10 should be right at flush, zero just outside of the fender. No “poke” is a good thing in my opinion.
Conman
Alabama
2018 JLU Rubicon
Where did you get the tow loop?
CarbonSteel
Those are Maximus-3 tow loops, but given the $hitty support they have given on the safety/design issues on the front tow loops, I no longer recommend them.
CarbonSteel
I believe with +10mm, you will still have some poke--look at mine at the bottom of the rear fender, I probably have 1-1/2" of tire out of the fender edge (not counting the XR extension). It is harder to see on the front fenders because they taper, but the rear fenders are fairly straight.
CBJB
Kansas
2016 JKU Sport, 2021 JL 80th Anniversary
I have the Quadratec Morphic wheel but in black with 315/70/17 KO2s. They stick out about 2.25”-2.5” from fender flares.
Jeep Wrangler JL Does Anyone Make Wider Rubicon Style Wheels? 0AA05C1D-DB08-4D49-99E0-0E5B1B4363CB
Jeep Wrangler JL Does Anyone Make Wider Rubicon Style Wheels? 99E6EFD7-60D3-4E8E-B260-AA5C51272669
Jeep Wrangler JL Does Anyone Make Wider Rubicon Style Wheels? F16A2E02-531E-4553-9DBC-82EA6ADBB17A
Jeep Wrangler JL Does Anyone Make Wider Rubicon Style Wheels? 0903BB90-FFD1-4601-BA22-6D707D35C092
