UncleJimmy
I am running a Vevor 5kw diesel heater outside the tent running through a 4 inch diameter dryer vent hose. I am getting some off gassing from the hose which gets worse the higher the heat setting. Has anyone found a vent hose that does not off gas?
this is the hose I am currently using. Says it’s coated with PVC which is probably not good.
https://a.co/d/cttfnDV
